SurgeX SX15 iR2 surge suppressor
unc2701
$85 shipped to lower 48. Might have the box somewhere, but don't count on it.
Lightly used, series mode suppressor, can take 1000 surges at 6000v, 3000amp with 0 failures.
Backburner:Krell KAV-300i
Post edited by unc2701 on
Found the box & manual.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
Picture is a little blurry, but there it is. Box, manual, all the original packaging are included. The only difference between this one and the current model is the color scheme and the new one has some mounting hardware.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Does this limit current flow at all?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Nope. 15a in 15a out. Manual attached.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Anyone? Doesn't get more bulletproof than this.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Yep, but anything downstream is protected, so you can plug another strip into it. Since it passes the full 15a, you could plug your amp into one outlet, then a standard surge strip w/ MOV's into the other outlet. Both would benefit from the series mode protection.
I found some other surge products seemed to cut dynamics when used on my amp- this had no effect at all, completely seamless.
In a different application: My VPI speedbox was introducing some humming on my TT; plugging it into the surgex somehow solved this.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Sold! Thanks, everyone.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Congrats on the sale,SurgeX makes great stuff.I've been looking for a deal on a used XQ515 or XR315 unit ,but nobody wants to let go of theirs,lol.
