CSiA6 - Large or small ?
Hi all,
Please, may I set my center channel in the receiver set up as small or large ?
While CSiA6 is a large center speaker, I am not sure if setting the center channel as large in the "receiver set up" should be done only if I had something like a RTiA9 there...
Thanks,
Mongo
Thanks,
Mongo
Receiver: Marantz - SR6006
Main: RTi A9's (powered by 2 Emotiva XPA-1`s, bi-amp)
Center: CSi A6
Surrounds: RTiA5's
(center and surrounds powered by Emotiva XPA-5)
Subwoofer: Infinity PS312
TV Sharp 70"
Center: CSi A6
Surrounds: RTiA5's
TV Sharp 70"
Post edited by Mongo on
small of course, set it to anywhere between 60-80hz will do
I have a CSiA6, and i have it set small 80HzSamsung PN50B550 Plasma
Pioneer Elite SC-25
Pioneer Elite BDP-23FD
Adcom 7500 Amp-Panamax 4300 Conditioner
Polk RTi10's Fronts
Polk Csi A6 Center-Polk M60s rear Surrounds
Klipsch Synergy Sub-10 X2
Klipsch Synergy S-10 Premium back surround -
Set it to small. An XO point of around 80hz is typically best.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
X4 ^^^^^Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s -
^^^^ x5
Try both and see what sounds best.
Small and 80hz.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Thanks to everybody that replied,
I am unfamiliar with this 80 Hz setting, would anyone please give memore details ?
I have gone through my old receiver manual, there`s a 5 band equalizer to adjust the center channel, but I am not sure on how to proceed,
Thanks a lot,
MongoReceiver: Marantz - SR6006
Center: CSi A6
Surrounds: RTiA5's
TV Sharp 70" -
Candygram for Mongo.2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
Thanks a lot,
Mongo
Large means that the full frequency output is sent to the speaker. Small splits the output at the specified frequency (sloped output, actually) and sends the lower freq signals to the bass producing speakers, most often a sub but sometimes the main speakers. If you have the "small / large" option you will also have the ability to select this frequency. Standard, and a good starting point, is 80hz.Home Theater
Polk RTi8
Polk Monitor 40
Polk CSi5
Polk MicroPro 2000
Visio 42 LCD
Denon AVR 790
Samsung BD 1600
Two Channel
Polk SDA 2B -
Small but I toy with the crossover in my SC07 set to 50 or 80 Hz.Shoot the jumper.....................BALLIN.............!!!!!
Thanks for clarifying, I was confused with the initial comment of setting the center channel to 80Hz - which doesn`t make sense, as this is the sub setting, that I set as soon as I bought the whole system.
Thanks again,
Center: CSi A6
Surrounds: RTiA5's
TV Sharp 70"
