SDA CRS+ from Santa Fe
jimbo1421
jimbo1421 Posts: 772
edited July 2011 in Vintage Speakers
Hello all,
There must be a nest of Polks somewhere just southwest of Santa Fe near La Cienaga. This is the third pair I have bought within a 5 mile radius. If only I could find the queen I'd be RICH!
These SDA CRS+ flunked the press test and were missing the pin/blade interconnect. I think I will try Armacell for gasket material this time. I need to make a temporary IC. I recall reading here that only the pin carries a signal. Is this correct? Can I just stick a bare wire (perhaps tinned with solder) into the pin sockets for testing purposes? Once I have completed testing I can decide on a repair and upgrade path.
I currently have my SDA-1Bs as shown here in post #55 http://www.polkaudio.com/forums/showthread.php?t=85190&page=2. Except that there is 6'-0" between the speakers and the listening position is closer to the south wall. The dining room to the right adds 14'-0" to the width of the room.
I am thinking that the CRS+ might work better in this situation, since the room is only 13'-2" deep.
Any thoughts?
Regards,
Jim
5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro
Post edited by jimbo1421 on
    F1nut Posts: 51,783
    edited July 2011
    As a temporary solution, your idea will work.
    Toolfan66 Posts: 18,066
    edited July 2011
    How do you do a press test with the grill on the back of the speaker covering the passive??
  • jimbo1421
    edited July 2011
    I removed the grill and refastened the PR. Pressing on the PR, the MWs return to center in less than 1 second.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • jimbo1421
    edited July 2011
    Thanks, F1. I will try it this evening.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
    edited July 2011
    That's what I figured you did, was wondering if someone would go through the trouble.. LOL!!
  • nspindel
    nspindel Posts: 5,343
    edited July 2011
    jimbo1421 wrote: »
    Jim
    Doesn't that mean the test succeeded? The faster the MW's return to position, the better the air seal. After I finished my armacell mod, there was zero delay - the MW's move in unison with pressing on the passive.
    edited July 2011
    They should draw back slowly..You have an air leak my good man!!
  • nspindel
    edited July 2011
    Only if I hold the PR pressed in, though, right? If I push the PR in, MW's should pop out. If I release the PR, the MW's should pop back in. I would expect a fully sealed cabinet should behave that way. If I push the PR in and hold it, and the MW's come right back in, then I would think there is an air leak.
  • jimbo1421
    edited July 2011
    I should have said "press and hold the PR in". The MWs push out, then pop right back in. I.e., they leak, badly.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • evhudsons
    evhudsons Posts: 1,175
    edited July 2011
    wow, I never heard of this test. It obviously explains why sealing the drivers is important. Part of my next of many steps.
