Upgrade/ Mod necessary?
rromeo923
rromeo923 Posts: 1,513
edited July 2011 in Vintage Speakers
I have had my SDA 1C's about six months. The previous owner used them for about six months and then they sat in original boxes in a closet for 20yrs.
I have done the sl2000 swap out to rd 194's with awesome results.
I am wondering about caps and resistors. Do they need replacing/upgrading with only a years worth of play? Or are they just getting broken in. I probably have less than 50 hrs of listening myself.
I got static in my head
Post edited by rromeo923 on
    treitz3 Posts: 19,952
    edited July 2011
    The resistors will be fine. The caps, however, do have a shelf life. What that shelf life is, I do not know anymore. It has been a while since I have been in the industry. Maybe someone else can chime in on that one.
  • drumminman
    drumminman Posts: 3,396
    edited July 2011
    rromeo923 wrote: »
    You can do a search here - this has been discussed many times. Conventional wisdom is that the caps and resistors should be upgraded if you want to really hear what these speakers can do. Not asnecessary to change out the inductors, though some here do.
    Film caps and non inductive wire wound reistors are much higher quality today than they were 20-30 years ago. Also, you have some electrolytic caps in the crossovers, which have their values drift over time even if they sit unused.
    It's no a lot of money compared with the upgrade in sound you'll get. And if you're not handy with a soldering iron there are folks on the board who would offer to do it for you.
    Toolfan66 Posts: 17,994
    edited July 2011
    Are you happy with what your hearing??
    Do you want to spend around $300-$400 on upgrades to the crossovers?
    Just a couple questions to think about, Is it worth it? IMO "YES"!!!
    Do you have spikes on them? If not DO IT!!! you will be floored..
    Good Luck!! Soldering and upgrading crossovers is a lot of fun and addicting,,
    F1nut Posts: 51,698
    edited July 2011
    Necessary? No. Advised? You bet.
  • CoachP
    CoachP Posts: 8
    edited July 2011
    Any suggestions for the type of spikes to use? I am considering modding my SDA 2's.
    F1nut Posts: 51,698
    edited July 2011
  • CoachP
    CoachP Posts: 8
    edited July 2011
    Thanks for the thread F1nut. Very informative and helpful.
  • rromeo923
    edited July 2011
    Anyone in Maryland have a pair of SDA 1C's that have been modded that I could possibly listen to???
  • xoaphexox
    xoaphexox Posts: 247
    edited July 2011
    I picked up my SDA spikes here and have been very happy: http://www.myesound.com/
    Burson HA-160D > Adcom GFA-5802 > Polk SDA-SRS 1.2tl w/ Mye Sound Spikes, Mills/Sonicap XO, Larry's Rings, Dynamat Extreme, Cardas CCGR Binding Posts and Jumpers, Custom 10ga interconnect, Custom Gaskets, RDO-198
    heiney9 Posts: 25,409
    edited July 2011
    Components like caps, resistors, etc have a shelf life even if they aren't powered up. Also capacitor technology has come a long way in 20+ years, not to mention it's more affordable.
    It makes no difference how much a passive component like a cap or resistor is used as long at it's not abused it wears about the same as a component in a box unused.
    The answer is yes.
  • inspiredsports
    inspiredsports Posts: 5,502
    edited July 2011
    heiney9 wrote: »
    . . . the answer is yes.
    It's a fact of life that capacitance drops as capacitors age. This will cause the crossover points to rise above originally designed values and it will affect sound quality. 20+ years is pushing it with the caps Polk used back then.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
    edited July 2011
    heiney9 wrote: »
    I'd like to kindly clarify this on one thing, if I may. Most common/standard resistors do not have a shelf life and common/standard resistors were most likely used in the production of these speakers. The ends may rust or corrode while sitting on a shelf or within a component, but the value does not change over time. Since these speakers were basically used for six months [according to the seller] and then stored for about twenty years, there was no current flowing through the resistors, thus no heat source to heat them up. Most failures I have encountered ended up as an open circuit over time or loss of value due to thermal [or current] overload and can even be caused by too much thermal heat upon installation. This is normally indicated by the tell-tale browning of the resistor and the board but may not always be the case. Now if moisture, weight, mechanical stress or excessive heat from storage has cracked the casing, that's another issue.
    One way to be certain that the resistors still hold the same value is to measure them, which wouldn't be a bad idea in case the previous owner swapped one out with the wrong value or if one has been excessively overheated, causing an abnormal value.
    That said, while I haven't tried it myself yet, positive things have been mentioned with upgraded or the use of tighter tolerance resistors [Mills, for example]. That may be something that you would want to research a bit.
    edited July 2011
    Ok Tom, I'll agree with you on resistor shelf life. The Mills are leaps and bounds better sounding. I'll take those over a .03c resistor new or 20 years old everytime.
  • Big Dawg
    Big Dawg Posts: 2,005
    edited July 2011
    xoaphexox wrote: »
    Not sure when you bought yours, but they're no longer available from Myesound.
