Concrete board under wood floors?
VR3
I would like to do put concrete board under my wood floor when I redo my den to reinforce it...
What do you guys think? Any reason this would be a no go?
Post edited by VR3 on
Not sure if it's a no go, but I've never seen it done. Why does the floor need reinforcing? Flexing?
I'm guessing he wants it because wood floors resonate more than concrete. So concrete board might be the next best thing to concrete slab? I dunno, just guessing.
Good Guess!!! Audiophiles are always thinking!!!!
A little bit of everything - for audio purposes, flexing... and... concrete board is just awesome!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I would be more interested in putting it behind the sheet-rock on the walls. Mainly to keep out the boom boom from cars, and when inconsiderate neighbors play their stereo outside. A side-effect is it would keep my HT booms, and stereo noise inside the house.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
BlueFox you're doing it all wrong. You don't deal with noisy neighbors by keeping their noise out, you deal with them by drowning their noise in your own noise
Airplay355 wrote: »BlueFox you're doing it all wrong. You don't deal with noisy neighbors by keeping their noise out, you deal with them by drowning their noise in your own noise
Yup thats where the fun starts !
Nothing better than a big system on tap when a neighbor thinks he can drown you out -
Yes. And no. That is what starts fights, and then everybody loses. I do call the police when necessary and let them deal with it, but you can't call the police for every thing. Rather than wearing ear plugs and hearing protectors, it would be better to have a home that provides a bit of noise insulation. Who knows. It might even be more energy efficient.
One of the more irritating things for me is working all day, coming home to relax while listening to a string quartet, and thinking, "I do not remember boom boom boom being in this before. Oh, it is some bass-hole down the street." :rolleyes:Lumin X1 file player, Westminster Labs interconnect cable
Concrete board would be excessive for noise isolation...
There are much more effective methods than that...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
There is there dense hard foam they use in airports between the studs I only know it as grillblocks or stink foam its kinda like pumice block , you can decrease mids/highs but low freq stuff will go out regardless ( I think )
but the pricey stuff is windows and doors listening studios use a dual door setup I have heard of a secondary wall that is 2 feet away with offset studs .
Its all pricey (material) except the drywall version but I am not to sure how well that works , I think using aura bass shakers in the furniture instead of real subs is supposed to cut the lingering bass down , and no windows .. -
I would say no myself. Wood and concrete generally don't go well together. You would also then have to glue down the hardwood floor as nailing through the concrete board would be messy and likely not hold well.
Just my thoughts.
MikeModwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote -
Do you mean "wonder board" or "durock"? The backerboard you would use for tile. Probably not the best. I've never used it as a subfloor. It kinda depends on what type of subfloor you have now. Do you know?
depends on the wood floor material
glue down
floating
nail / staple
see
http://www.hardwoodcouncil.com/
http://www.woodweb.com/knowledge_base/Installing_Hardwood_Floors.html -
^^+1^^
Either add more joists,beams & posts or do a double layer of T&G 3/4" Sturdifloor plywood with a buttload of PL Premium polyurethane construction adhesive between the layers. Screw the top sheets to the lower ones with a 8" square grid pattern. -
Its not a huge concern, just a possible idea!
The floor is currently old slat wood with solid oak 1.5" strip
I plan to add like a 1/2" or so layer of plywood then float a wood floor over it in the future- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
1/2" Durock bedded in thinset on top of 3/4" Sturdifloor ply nailed with 1 3/4" ringshank nails provided the base for my 12" sq. ceramic tile kitchen floor. Like a rock! -
Older home? Probably 3/4 boards run at 45 degrees to the joists that are 16" on center. Then 3/4 oak flooring over the top for a total of 1.5 inches. This should be plenty strong for a floating floor. The one concern I would have would be squeaks in the subfloor (3/4 pine boards). Screws can fix that problem though.
GDB, Yes, that's the best way to install tile. Most tile setters want a minimum of 1 1/4 inches under the tile. With at least 2x10 floor joists. -
Nope,T&G ply glued & nailed to joists 16" OC ( house IS ancient though!)
