An odd solution...
VR3
I have been searching for a cheap 2 channel subwoofer - for a while as I just dont need anything that will dig ultra low - 30, 25hz is perfect) but I wanted something small that would take up little floor space and wanted it to be cheap..
I came across another set of BP2006TL towers and this time I decided I would try them running dedicated as just subs in my 2 channel setup...
These are just a little 8" woofer that hit solid to 30hz or so, maybe a little lower in room - they have a fixed crossover and a volume knob...
I plugged them up - one per side... blended the volume (still playing with them) - and so far I really really like them.
Whats even cooler about them is they are tiny, take up maybe .5 sq ft if that.. so yeah - totally awesome...
Wanted to share my odd solution to my stereo subwoofer woes...
Still not sure if this is a final thing... just playing around!
Post edited by VR3 on
Early AR speakers were designed to be used as bass units only as well as a normal full range speakers. So your solution is not so odd really. Good for you that it works.
cubdogShuguang Classic S8MK
Emotiva XDA-2
Bel Canto M300 mono blocks
Bel Canto DAC 1.5
Squeezebox Touch
Sony SS-M7
A/D/S L710 -
Thanks!
Yeah the more I listen the more I like it... it seems to blend really well - and digs low enough to add a bit of thunder to some recordings...
Although I think I may search out something like a Supercube III down the road to run per side- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
cubdog
I bought some 4x AR's from CL for $50 awhile back, hooked them up in the main system on some phone books, and man, was there bass coming from those little 19x10 boxes...Roy Allison design I think?
Way cool speaks
I have them in the 'puter room with a Kennie Basic amp, they do like some juice :biggrin:
Congrats Vr, have fun playin' with the bass!Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's
