Hey Doc?
Do you think my VEL CHT 12" could hang in there for the "Ring Drop" in LOTR?Have not had a chance to try it yet but wanted an expert's opinion.thanks.
  1. RTi 70
  2. CSi 40
  3. r30
  4. r15
  5. Velodyne 12" sub
  6. H/K AVR520
  7. PS3
  8. Xbox 360
  9. Bell HD satellite 6100
  10. Samsung 4665 HDTV
Post edited by Digital Daddy on
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited September 2003
    Yes - according to Tom Nousaine, the Velo 12" was one of the few subs in that price range that had true extension into the low 20 Hz range.
    SVS
  • hamzahsh
    hamzahsh Posts: 439
    Doc, I have a Velo CHT-15 so what would
    be the Deepest Extension ??hz for it?
    Is there a way to find out?
    Panasonic TH-50PX80U Plasma HDTV
    Polk Audio RT800i (fronts)
    Polk Audio CS400i (center)
    Polk Audio F/X1000 (side surrounds)
    Polk Audio RTi6 (back surrrounds)
    Velodyne CHT-15 (subwoofer)
    Yamaha RX-V1400 (Pre/Pro)
    NAD C272 (2-ch Amp)
    Adcom GFA-7605 (5-ch Amp)
    Toshiba SD-3109 (DVD/CD player)
    Malata DVP-580 (Multi-region DVD player)
  • Dr. Spec
    Other than doing a sweep in room, try the website or do a search for reviews and see if someone else tested it. I would imagine in probably digs into the low 20's as well.
    SVS
  • goingganzo
    goingganzo Posts: 2,793
    yes the cht 12 or ct120 is one of the better subs for the price besides svs and diy.
    if i was not so good at diy i would have went with a seccond ct120 for added bass.
    the olny thing the velo is very stiff when you first get it and it takes a week or to get it to realey thump.
