High pass filter on psw125
EDUBAG
Hello guys,
Just wondering if anybody knows the frequency at which the high pass filter on the psw125 is fixed?
Meaning at what frequency the subwoofer filters everything from, when using the high pass filter built into the subwoofer.
This question is because I am going to use a 2.1 system and would like to know what frequencies the bookshelf will be receiving.
Regards,
Eduardo
Regards,
Eduardo
HT:
POLK AUDIO RTI4 FRONTS
CSI3 CENTER
DEF TECH PROMONITOR800 SURROUNDS
PSW 125 SUB
PIONEER ELITE AVR23TXH AVR
APPLE TV 160GB
PANASONIC BLURAY PLAYER
50" PANASONIC PLASMA TCP50C2
2 CHANNEL:
KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
OPPO DV980 (AS CD PLAYER)
PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
MIT EXP2 SPEAKER CABLES
CSI3 CENTER
PSW 125 SUB
APPLE TV 160GB
2 CHANNEL:
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
Post edited by EDUBAG on
If it's like the PSW110, the dial is a Low Pass dial and only affects the sub output frequency.
Using a speaker level connection, the sub will output frequencies at and below the Low Pass dial setting and the speakers will always get full range output regardless of the low pass dial setting.
Using a line level (LFE) connection, the Low Pass dial setting will combine with the receiver's crossover setting (if available) thus double-filtering the sound. -
Eduardo, although a very few subs do have a separate fixed(commonly at 100Hz)high-pass filter on their speaker level outputs, it doesn't appear that the PSW125 is one of them. If you have specific information to the contrary, you should contact Polk directly for details that don't appear in their materials.
If not, and you have a filtered sub output from your receiver or processor, you should connect it to the unfiltered LFE input on the PSW125 and connect the speakers directly to the receiver/amplifier. If you don't have bass management available in your receiver or processor, the low-pass filter control on the sub will roll it off above(roughly)the selected frequency, but this isn't a crossover(subs don't have internal crossovers)and has no effect on the speakers, which would have to run full-range. -
thank you fir th info,
i guess it does not have a fixed high pass filter, which is what i need to hook up a sub to my audioengine p4 speakers, the amp is a small desktop amp by them as well.
thank you all,
EdHT:
CSI3 CENTER
PSW 125 SUB
APPLE TV 160GB
2 CHANNEL:
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
