is warm up time a waste or better to wait for optimum
leftwinger57
leftwinger57 Posts: 2,917
edited July 2011 in 2 Channel Audio
Hello , Today I'm on a tear and the questions keep on rolling off the old noggin.
I,m a ss amp and a ss- pre amp guy so tubes are a foreign entity to me. From what I have heard here and on other forums ,you need warm /up time for optimum performance. This is a pretty clear blanket statement and I want to know 1. how true is it and 2. how long do let it warm up before getting any entertainment out of this very expensive gear.i do relise that all tubes react differently so there might not be any concise answer,but judging by all accounts the tube owners would not convert even if it was a free gift. So if you can
explain the fasination of the tube world vs. the immediacy of solid state.
    tonyb Posts: 33,029
    edited July 2011
    1-yes it's true
    2- your ears will let you know,usually 20-30 min on average I would guess.
    Tubes bring some soul,some air, some musicality back to the sound, thats the best way I can describe it.
    nooshinjohn Posts: 25,484
    edited July 2011
    I agree with Tony, but with tubes, my short experience has shown me that the more I sit ands listen, the morer ewarding that experience becomes, as the tubes tend to get even better over a span of an hour or so. If I know I will have an opportunity to relax with some music, I will turn things on and leave them on for a few hours beforehand.
    My Cinema 425/5 stays on all the time.
    heiney9 Posts: 25,221
    edited July 2011
    For tubes warm-up is essential. For higher end SS designs it can vary from 15 minutes to a couple hours. All of your switching type amps (Class G, H, D and hybrids) it doesn't matter per se.
  • FTGV
    FTGV Posts: 3,649
    edited July 2011
    Anything that requires bias usually needs a warm up period for the semiconductors to reach operating temp and for the bias current to stablize.
    F1nut Posts: 50,843
    edited July 2011
    My main rig takes days to "warm up". My all tube office rig sounds great after 5 minutes.
  • stuwee
    stuwee Posts: 1,508
    edited July 2011
    I'd love to leave my SS amps on all the time, but with Martin Logans it triggers the sensor to power up the panels which means they'll be atracting dust. A big no-no, I vacuum them once a month and that's plenty for me. I find after 15mins the sound gets richer and after 30mins it's even better.
    Some equipment that I'm not using gets pulled out and plugged in for a few days every 6 months, just because I think it helps in the long run.
    Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's
  • headrott
    headrott Posts: 5,496
    edited July 2011
    As I have stated previously in another thread; my Aragon 8008bb SS amp will send high end spikes through your head if you listen to it before (approximately) one hour warm up time. It really is harsh on the ears and brain without the warmup. As others have stated, tubes generally need more to warm up from my exprerience. Honestly, I have never left my rig on for more than a day at one time, so I cannot say what days will do to the sound. But I can say unequivocally, that 30 minutes, 1 hour, 2 hours and more (depending on the gear used) will improve the sound of both SS and tubed gear. With the greater improvement going to the tubed gear, generally. Also, some gear will express the greater improvement with warmup more than other peices of gear, depending on design, parts used, etc.
    Greg
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited July 2011
    I've found that some warm up time makes my all SS rig sound better. If I turn it on and immediately start listening, it's a little sterile sounding, and doesn't have as much warmth and definition. In my experience, about half an hour of warm up time is good. Obviously though, that's going to vary depending on your specific equipment.
    Generally, I don't bother waiting for it to warm up though. I'll just turn it on and start listening...it gradually gets better sounding as it warms up. I'll usually just leave it on all day, unless I know I'm going to be leaving for a long period of time.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
    edited July 2011
    Straight from the owners manual. Single ended Class A solid state amplifier. I concur 100% based on my listening experience with this amp.
    It takes about an hour of warm up time to get the best performance out of the amplifier. It will take that long to reach operating temperature and exhibit lowest distortion and noise. This is not a subjective judgement, but based on actual distortion and noise measurements. Many customers have reported that longer warm up yields more improvement.
  • Joe08867
    Joe08867 Posts: 3,919
    edited July 2011
    I will just copy and paste what I wrote in your other thread. Warm up isn't smoke and mirrors, it is a truth. I have also seen some SS gear that need warm up to sound great. Especially some older amps and receivers. But as far as tubes go.
    I left my Tube preamp on most of the time. Like madmax said they can and usually do take longer to stabilize and sound as they should.
    I turned my Tube amps on 1-2 hours before I listen to them. I shoot for 2 hours but anytime after an hour was usually enough for them to sound like they should.
    If I just came in the house and turned everything on at once and started playing music right away it sounded very poor. Tubes can be awesome but they take some planning and patience, but in the end you are rewarded with wonderful, immersing sound.
  • BlueFox
    BlueFox Posts: 15,251
    edited July 2011
    On weekends I turn my system on Friday night when I get home from work, and leave it on until bedtime Sunday night. Although I cannot prove it, it certainly seems to sound better on Saturday.
  • TroyD
    TroyD Posts: 13,093
    edited July 2011
    I KNOW my rig sounds better after a period of time, however, I don't stress over it. I primarily listen for enjoyment. When listening becomes like doing long division, I'm done.
    BDT
  • megasat16
    megasat16 Posts: 3,521
    edited July 2011
    You main rig running from 60V power system? I have never heard a system that takes days to warm up before.
    My all pure Class A SS amp takes about an hour to fully warm up. You can fry bacon and cook dinner on top of the amp.
    My all tube preamp takes about 30 minutes to fully warm up and ready.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • cubdog
    cubdog Posts: 835
    edited July 2011
    Bel Canto recommends leaving their amps on 24/7 so I do. When I had a tube integrated I couldn't tell any difference in sound 5 minutes or 5 hours after I turned it on. But my hearing sucks. :frown:
    cubdog
    Shuguang Classic S8MK
    Emotiva XDA-2
    Bel Canto M300 mono blocks
    Bel Canto DAC 1.5
    Squeezebox Touch
    Sony SS-M7
    A/D/S L710
    F1nut Posts: 50,843
    edited July 2011
    megasat16 wrote: »
    Yeah, I don't know how to explain other than to say it seems to sound better after a few days. I actually leave it on 24/7 unless there's a thunderstorm.
  • george daniel
    george daniel Posts: 12,096
    edited July 2011
    he,he,, ask Klaus.:smile:
    treitz3 Posts: 19,279
    edited July 2011
    Same here. The way I would explain it would be that while the frequencies may not change, the subtleties, the texture, the attack, the sharpness and definition thereof [concerning the frequencies] do. Most importantly the sound stage and spatial location cues along with the aforementioned all come in to a musical fruition. On some systems, less grain and a more organic sound comes with keeping the rig on and letting everything stabilize to normal [or optimum] operating temperature.
    YMMV and this is not only rig dependent, it is listener dependent as well.
    edited July 2011
    Oh, jeeeez. Don't get me started on what happens with his amps. Until day three, any myriad of things [not for the good] can happen. It's like the amp is on a three day high off of some REALLY good drugs and on day three, it sobers up and everything falls into place. At that point, you can listen.
    This is, of course, after the break in period. :eek:
  • decal
    decal Posts: 3,205
    edited July 2011
    Also, your brain gets accoustomed to the sound the longer you listen. This has a lot to do with the warm up period,IMHO. BTW, you started a thread 2 days ago on basically the same thing. Wait til H9 finds out!!!!!:eek:
  • victor. askew
    victor. askew Posts: 50
    edited July 2011
    I just leave mine on all of the time if its in the rotation to be played.Im not sure if this affects( improves) its sound or not but I do try to keep everything as warm and as stable as possible with the amps, pre amps and CD player. I have never had any breakdowns of any of my equiment due to doing this and the draw on the elect bill is small, on avg $5/7 a month.:smile:
    Amps- Nakamichi PA 7 & PA 5.
    P Amp- Classie Audio. Nakamichi CA 5
    Tape- Tandberg 3014A.
    Tape- Nakamichi 600.
    CD Calif Audio Tercet 3.
    CD-Rotel 1078.
    Spkrs- Polk Audio RTI 150 Towers.
    Spkrs- ADS L1290 Towers.
    Spkrs- Yamaha- NS 670,NS 500m,NS 200m, NS 200ma
    NS 200ma hybrids.
  • Flash21
    Flash21 Posts: 316
    edited July 2011
    cubdog wrote: »
    Sure, but it's easy with a Bel Canto...hardly takes any power at all.:smile:
    Steve Carlson
    Von Schweikert VR-33 speakers
    Bel Canto eVo2i integrated amp
    Bel Canto PL-2 universal disc player
    Analysis Plus Oval Nine speaker cables and Copper Oval-In Micro interconnects
    VH Audio Flavor 4 power cables
    Polk Monitor 10B speakers, retired but not forgotten
  • thetawave2
    thetawave2 Posts: 268
    edited July 2011
    Would leaving a tube amp on constantly adversely affect the lifespan of the tubes?
    My Stereo: Tannoy D100s, Yaqin MC-100B, VPI Traveler, Dynavector 10x5 MC Phono Cartridge, heavily modified Yaqin MS-22B phono preamp, TEAC EQA-20 equalizer, Belkin PureAV PF30 Power Conditioner, Canare 4s11 speaker cables, Custom dust cover from DigitalDeckCovers
    edited July 2011
    thetawave2 wrote: »
    Yes, it certainly would. It depends on the tube and the position the tube is in. Power tubes have shorter life than small signal tubes and some NOS tubes seem to last forever and will run circles around just about anything manufactured today.
    Why would you want to leave a piece of tube gear on constantly? To me that means 24/7.
  • thetawave2
    edited July 2011
    I have heard of some people leaving tube gear on 24/7... doesn't really sound like something I would want to do haha
    Just trying to learn a bit about tubes. I might be moving in that direction for the first time come winter.
    edited July 2011
    I would say if you're going to be listening to them it's alright to leave them on for an entire day, if you are home, etc. I wouldn't recommend leaving tube gear on and unattended for long periods of time.
    It's better to power the tubes up and leave them running, than it is to constantly power them off and on. Example, you want to listen in the morning so you power them up, by 10:00am you want to do laundry, and things around the house, etc. but again at 3:00pm you want to listen. It's better to leave the tubes powered up from the early Morning through 3:00pm than to power off and on a few times in that same time period.
