diff. in rta 12 drivera
soundfreak1
soundfreak1 Posts: 3,414
edited July 2011 in Vintage Speakers
What is the diff. Between the mw 6600 and the mw 6501 as far as sound . The 12's have both type installed but what is the real diff.
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
Post edited by soundfreak1 on
  • Joe08867
    Joe08867 Posts: 3,919
    edited July 2011
    A quick explanation by H9
    heiney9 wrote: »
    Why does any manufacturer use different drivers for different positions in a speaker design. They used different drivers because they needed the drivers to have sightly different characteristics in order for them to sound the way they wanted them in their design.
    That's the "why"; as to the differences, the engineers would know, but you don't need to know the differences because you probably wouldn't understand how they correlate to the speaker design. I'm sure the "f", "q", and other parameters are different as well as the impedence, etc. You need to know what you need in your particular model speaker and replace with the same thing.
  • geppy1
    geppy1 Posts: 3,076
    edited July 2011
    I forgot to call you I willl tonight. The 6600 and 6501 DO NOT sound the same at all.
    pitdogg2 Posts: 26,953
    edited July 2011
    yep my SDA1 signatures use mw6600 for bass and stereo drivers and mw6501 for diminsional drivers. I can't remember but i thought the 6501 was 8ohm so if it connected through the diminsiona XO's would that make it 4ohm? or do i have it backwards?
