Look what showed up today....
I-SIG
I-SIG Posts: 2,243
edited July 2011 in The Clubhouse
:tongue::biggrin::cool:
Wes
Link: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
Post edited by I-SIG on
  • BlueFox
    BlueFox Posts: 15,251
    edited July 2011
    What is it? A cleverly disguised illegal immigrant? :confused:
  • jbooker82
    jbooker82 Posts: 1,627
    edited July 2011
    Looks like a burlap coffee bean sack streatched over a frame to be used as a picture.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • I-SIG
    I-SIG Posts: 2,243
    edited July 2011
    jbooker82 wrote: »
    You're half-way there. The other half is that these are the ATS Acoustics "Coffee Bag Panels."
    http://www.atsacoustics.com/item--ATS-Acoustics-Coffee-Bag-Acoustic-Panel--3001.html
    Wes
  • jbooker82
    edited July 2011
    ahh so it has a purpose other than looks
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited July 2011
    I-SIG wrote: »
    Wes
    Really neat idea! :cool:
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • I-SIG
    I-SIG Posts: 2,243
    edited July 2011
    TECHNOKID wrote: »
    I thought it was too. I'm gonna put another row above the ones I have shown. It's a small start to dampening my tile and sheetrock room a bit.
    Wes
  • TECHNOKID
    edited July 2011
    I-SIG wrote: »
    Wes
    It is nice to see acoustic panels that looks more of a home decor than simple accoustic panel while still accomplishing the task. Such makes it a whole lot easier when considering-seeking WAF.
    DARE TO SOAR:
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited July 2011
    So why are they in the kitchen and not by the speakers?
  • TECHNOKID
    edited July 2011
    I-SIG wrote: »
    Wes
    If you allow constructive comments, IMHO they would look much nicer on your wall if they were offset instead of a straight line (specially if you are to add more panels). What do you think?
    DARE TO SOAR:
  • I-SIG
    I-SIG Posts: 2,243
    edited July 2011
    TECHNOKID wrote: »
    That's a good idea. I was thinking about it, but I just don't know if I have the right or enough wall to work as well as I would like. Thanks!
    Wes
  • dorokusai
    dorokusai Posts: 25,577
    edited July 2011
    Those look great!
  • I-SIG
    I-SIG Posts: 2,243
    edited July 2011
    leroyjr1 wrote: »
    I have, for lack of a better way to put it, a semi-open plan. The living room and dining room are one open area and the kitchen is sort of open with a large entry and a bar counter open next to the DR table. This wall is directly opposite from the SRS's so they should still help attenuate first reflections, despite the distance.
    Unfortunately, the living room area has windows on the left wall directly next to the SRS's then a sliding glass door (both covered with fairly thick curtains). The right wall has a cubby hole for a TV stand (I put my sub next to the hole with a 2ft x 3ft panel planned across the corner for a bass trap) and then a fireplace with a riser for the chimney. The riser will get a 2ft x 4ft panel and there is an opening to the foyer area directly above the cubby hole.
    For better or worse, there just isn't wall space to hang much on next to the speakers. On the wall next to the kitchen entry, I plan to add a few panels at that first reflection point as well.
    Wes
  • I-SIG
    I-SIG Posts: 2,243
    edited July 2011
    dorokusai wrote: »
    Those look great!
    Thanks, Mark.
    Wes
  • stuwee
    stuwee Posts: 1,508
    edited July 2011
    Very cool Wes! Get some pot bags next time :tongue:
    Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's
  • Ricardo
    Ricardo Posts: 10,636
    edited July 2011
    At 60 kg each make sure you use strong anchors.:wink:
    Looks great.
    SOPA
