can you tell me if a jumper is needed
leftwinger57
leftwinger57 Posts: 2,917
edited July 2011 in Speakers
Hello, I have heard so much of these SRS-SDS speakers and how good they really are. The concern I have is that I keep hearing that you need a jumper between both speakers and in a house like mine that would be physically impossible unless yuo know how to either pull carpet or pull mouldings which as a former alarm installer I know how to do. So can someone please answer this question of a bonding wire between the two speakers. This is a curiosity that is bugging me.....lw
  • dorokusai
    dorokusai Posts: 25,576
    edited July 2011
    You need a cable to connect both loudspeakers. It's called an SDA cable and it comes in a couple forms depending on the speaker. It's not just a jumper as it is essential to the speaker working as intended and correctly.
