Cabinet glue for m5b
wanders
wanders Posts: 15
edited July 2011 in DIY, Mods & Tweaks
Found a set with a hole drilled through back panel. Plan to glue-in a short section of 1/2" dowel. Any suggestions for glue to secure the plug and seal the cabinet?
  • Joe08867
    Joe08867 Posts: 3,919
    edited July 2011
    Good old Wood Glue should do the trick. If you want more sealing mortite around the inside of the plug should do the trick.
  • Unknown
    edited July 2011
