Denon PMA-2000R Ultra High Current Integrated Amplifier
Conradicles
Giant Killer. Minty. That about sums it up for this beast. Not your typical Denon integrated amp. The engineers and manufacturing team at Denon hit this nail on the head.
I don't want to bore you with specs. Dual Mono design (don't use this with SDA's unless you use a A-1 cable) and current on demand, this will drive low impedance speakers with ease. Deep at about 19", so make sure you have room in your rack.
Mint condition and original remote included. Trimming down to one system from two, so this beauty needs to be enjoyed by somebody else.
$455 shipped via FedEx Ground with insurance. I'll cover the PayPal fees.
I'll post the specifications and data soon...
Here are some pictures and more to follow:
That's a very solid Integrated Amplifier and is a prime example of what Denon is capable of when they stop worrying about bells and whistles.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
The Product Sheet is attached via PDF. It has the goods.
Specifications:
- Power Amp Section
Rated output, both channels driven 80 W + 80 W (8 ohms, 20 - 20 kHz, 0.07%THD)
160 W + 160 W (4 ohms, DIN 1 kHz, 0.7%THD)
Total Harmonic Distortion 0.01% (-3 dB rated output, 8 ohms load)
- Preamplifier Section
Input sensitivity/Impedance
PHONO 2.5 mV/47 kohms (MM), 200 μV/100 ohms (MC)
CD, TUNER, DVD/AUX 150 mV/47 kohms (Source Direct OFF)
TAPE-1/DAT, TAPE-2/MD 150 mV/47 kohms (Source Direct OFF), 150 mV/13 kohms (Source Direct ON)
RIAA deviation/PHONO 20 Hz ~ 20 kHz ?0.3 dB (MM/MC)
- General Characteristics
S/N ratio (A-weighted)
PHONO 91 dB (MM), 76 dB (MC)
CD, TUNER, DVD/AUX 110 dB (input terminals shorted/Source Direct ON)
Tone controls 100 Hz ?8 dB (BASS), 10 kHz ?8 dB (TREBLE)
- Other Specifications
Power supply AC 120 V, 60 Hz
Power consumption 6 A
Dimensions 434 (W) x 180 (H) x 478 (D) mm (including feet, knobs, terminals)
17-1/8? x 7-1/8? x 18-3/4?
Weight 20.0 kg, 44 lbs -
I am from Toronto. Can you quote shipping to M2J 4V6, ON, Canada? email me at edchk@mac.com
Sold to an e-bay member. Thanks folks.
