tight interconnects
Oldfatdogs
Oldfatdogs Posts: 1,874
I bought some monoprice interconnect cables that are very tight going into the back of an amp.Is there anything I can put on them to make them slide easier? I don't want to break off the pin in the amp. Thanks Dan
  • djperez81
    djperez81 Posts: 388
    edited July 2011
    I had the same issues with my monoprice IC's. Are you able to get yours on? Mine were a tight fit but i got them on. Just be gentle with them dont think you should have a problem. Good luck.
    Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
    -Jimi Hendrix
  • dorokusai
    dorokusai Posts: 25,642
    edited July 2011
    CAIG Pro-Gold.
  • danger boy
    danger boy Posts: 15,722
    edited July 2011
    put some bacon grease on them, then you won't have that problem.. lol
    PolkFest 2012, who's going>?
  • TNRabbit
    TNRabbit Posts: 2,168
    edited July 2011
    Try wiping with DeOxit, & TWIST when you pull/push.
    Edit: Pro Gold will work, too
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • Oldfatdogs
    edited July 2011
    danger boy put some bacon grease on them, then you won't have that problem.. lol
    Your a funny guy. Thanks for the advice everyone.They go in but they are really tight.I knew I had to word this carefully,or all you dirty birds would have a heyday. :biggrin:
  • djperez81
    edited July 2011
    Oldfatdogs wrote: »
    Nothing wrong with a tight fit.:wink:
    -Jimi Hendrix
  • dorokusai
    edited July 2011
    Oldfatdogs wrote: »
    Oh I'm sure every single person thought that exact thing OFD...I know I did.
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited July 2011
    Had the same problem with mine I got from Microprice a couple of months ago. I was afraid I'd break the rca input on the receiver. Figured I'd play it safe and put the new cable on a piece of gear I didn't care about and that was enough to expand the outer sleeve to where it went on nice and easy on the receiver,yet felt firm.
    F1nut Posts: 52,356
    edited July 2011
    Don't buy such cheap cables.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited July 2011
    Sometimes people find it hard to justify spending hundreds, let alone thousands, of dollars on cables. I think some of you guys forget that not everyone has a nearly unlimited budget when it comes to audio gear. :wink:
    Some deoxit should help you slide those cables on. If that doesn't work, try a little KY warming liquid. :wink:
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • thsmith
    thsmith Posts: 6,082
    edited July 2011
    SIgnal cable sells some great budget cables, don't have to spend hundreds little alone thousands.
    I would think signal cable would be a lot better than monoprice. But hey if the OP is happy I guess that is all that matters.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited July 2011
    I have the monoprice ones and over time they loosen up a great deal
    I do plan to buy some more spendy ones soon but for now they are ok as I'm more in the HT direction
  • polkatese
    polkatese Posts: 6,767
    edited July 2011
    I don't have monoprice I/C but I used to have Monster M550. Those have grip of death and it gets worse over time. It has turbine fin grip that is a **** to take them off.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
    F1nut Posts: 52,356
    edited July 2011
    It's more like everyone seems to have the same problem with that brand and they are really cheap, so perhaps it's a case of you get what you pay for. As mentioned, Signal makes affordable cables that don't have that issue.
  • headrott
    headrott Posts: 5,496
    edited July 2011
    :biggrin::biggrin::biggrin:
    Good advice.
    Greg
  • Oldfatdogs
    edited July 2011
    OK, I had to get something for an old amp to play with.I didn't want to break the bank until I know if its worth it.These are for a old LAFAYETTE I picked up a while back.
