Two different AVRs responding to the same remote commands
27dnast
27dnast Posts: 255
edited September 2012 in Electronics
briefly... I'm trying to run an older pioneer vsx1016 and an Eite AVR.
Apparently they run on the exact same remote commands... and it's a little annoying to attempt to adjust the volume on one to only have the other react in the same manner!
Anyone have any idea as to what I could do to stop this?
Post edited by 27dnast on
  • codyc1ark
    codyc1ark Posts: 2,539
    edited July 2011
    Tape over the IR receiver?
    edited July 2011
    Better yet, why do you have 2 avrs in such close proximity that this even occurs ?
  • Joe08867
    Joe08867 Posts: 3,919
    edited July 2011
    What tonyb said? Are you doing a side by side?
  • 27dnast
    27dnast Posts: 255
    edited July 2011
    One is my primary AVR. The other is a secondary avr that is powering some bass shakers....
    Just didn't know if there is a way to change how a remote talks to an avr...
  • 27dnast
    27dnast Posts: 255
    edited July 2011
    codyc1ark wrote: »
    Yes... this is the one option I came up with... but I'd like to have remote control over the second avr if possible
  • jon s
    jon s Posts: 905
    edited July 2011
    There is no fix for this... A model lineup will usually have the same remote control commands throughout.
  • LessisNevermore
    LessisNevermore Posts: 1,519
    edited July 2011
    Try a universal remote. there might be a code that controls the volume of the secondary amp, that the other doesn't respond to.
  • codyc1ark
    edited July 2011
    What about moving the bass shaker AVR to a different location, I'm going to assume that you turn the volume up and down on this unit to match what your watching, or if you have music in. If you have a near field sub, you could set it on top of that, or if you had a two tier end table you could set it on the bottom shelf, and manually control it, or just lean over and point the remote to it, lets call that the lazy way. Are you using this unit to do anything that your not telling us? For example, powering a 'b' set of speakers somewhere else?
    Didn't you order like 6 or 8 bass shakers? Did you put a few on the bed also, for that magic finger touch when the mood hits? Nice...... :biggrin:
  • 27dnast
    27dnast Posts: 255
    edited July 2011
    Yes... 6 bass shakers. They are fantastic
  • 27dnast
    27dnast Posts: 255
    Just to update this... Pioneer allows you to change a devices remote code thus allowing a to talk to only one device. It's in the set-up menu. Easy to do, problem solved.
    And, yes, the bass shakers are still AWESOME
