Monitor 5 7 10's
emionence1963
What is the raw max pwr the midwoofers can handle, without crossover?
Is there a spec sheet on the parameters of the woofer somewhere here on the forums?
I have the owners manuals on each of these speakes and the pwr handling specs. But that is the whole speaker including crossover.
I just need the raw individual speaker specs!
Post edited by emionence1963 on
The Monitor 5 7 and 10 have used various mid-woofers over the years. I had found specs for several Polk mid-woofers used in these and other models.
Driver: MW 6500 Driver's model #.
Brand: Polk Driver's brand name.
Fs: 31.0000 Hz (Free air resonance)
Vas: 2.6486 ft^3 (Compliance volume)
Qts: 0.2190 Total Q
Qms: 1.3000 Mechanical Q
Qes: 0.2640 Electrical Q
Sd: 0.0130 M^2 (Piston area)
Xmax: 3.1800 mm (Cone excursion, linear)
Revc: 6.5000 ohms (DC resistance)
Znom: 8.0000 ohms (Nominal impedance)
Pmax: 35.0000 watts maximum rated power
Driver: MW 6501 Driver's model #.
Vas: 2.7545 ft^3 (Compliance volume)
Qts: 0.2790 Total Q
Qms: 1.4700 Mechanical Q
Qes: 0.3440 Electrical Q
Revc: 7.7500 ohms (DC resistance)
Driver: MW 6502 Driver's model #.
Fs: 44.0000 Hz (Free air resonance)
Vas: 1.2360 ft^3 (Compliance volume)
Qts: 0.2790 Total Q
Qms: 1.9700 Mechanical Q
Qes: 0.3250 Electrical Q
Revc: 3.5200 ohms (DC resistance)
Znom: 4.0000 ohms (Nominal impedance)
Driver: MW 6503 Driver's model #.
Fs: 29.8600 Hz (Free air resonance)
Vas: 3.0017 ft^3 (Compliance volume)
Qts: 0.3100 Total Q
Qms: 1.7680 Mechanical Q
Qes: 0.3760 Electrical Q
Revc: 6.5400 ohms (DC resistance)
Driver: MW 6517
BrandL Polk Audio
* Size / Type = 6.50" treater paper cone woofer
* SPL = 91 db @ 1w/1m
* Wattage = 125 Watts RMS / 250 Watts Peak
* Treated cone woofer, rubber surround
* Response = 40 Hz. to 10 kHz.
* Weight = Right a 4 pound ea.
* Magnet = UnShielded
* VC = 1" ( 25 mm)
* Ohms = 4 ohms
* f(s) - 55 Hz.
* Q(ms) - 7.261
* V(as) - 14.60 liters ( 0.516 cf. )
* n(0) - 5.02%
* M(ms) - 18.38 grams
* R(e) - 1.86 Ohms
* Q(es) - 0.048
* SPL - 92 dB @ 1W/1m
* C(ms) - 0.44 mm/N
* Z(max) - 281.50 Ohms
* Q(ts) - 0.048
* L(e) - 31.08 mHStan
Main 2ch:
HT:
Other stuff:
Holy cow!!!:)
Thanks! Just what I needed:biggrin:
