Painting RTA 8Ts
deronb1
deronb1 Posts: 5,021
edited July 2011 in Vintage Speakers
After upgrading the xovers on my 20+ yr old 8Ts, I was thinking of painting them. Can I paint right over the veneer? Or should I remove it?
Post edited by deronb1 on
  • Joe08867
    Joe08867 Posts: 3,919
    edited July 2011
    You should remove it.
  • deronb1
    edited July 2011
    Alrighty then. Thanks!
  • Joe08867
    edited July 2011
    You could try using a primer to help paint adhere but the finish may not be all that great.
  • deronb1
    edited July 2011
    Yeah, been reading up on it. Some folks say it's ok to paint over the veneer with primer and some say it snot. (I meant that)
  • Joe08867
    edited July 2011
    If it were me I would remove the veneer, clean up the cabinets to get a nice smooth surface and lay down a few coats of whatever color your looking for.
    I am guessing you want Black considering the BA's you just returned. Just take your time and sand them in between coats to get the best coverage.
    F1nut Posts: 51,793
    edited July 2011
    Are they actually wood veneer or vinyl laminate? Polk sold both.
  • deronb1
    edited July 2011
    not sure 1989 model. I will do some research. Thanks
  • deronb1
    edited July 2011
    RTA 8Ts are vinyl.
    F1nut Posts: 51,793
    edited July 2011
    Ok. There are paints designed to go over vinyl (plastic), but I do not recommend going that route.
    Do you have spray equipment?
  • nadams
    nadams Posts: 5,877
    edited July 2011
    I would strip the vinyl and do some nice wood veneer replacment :)
    Ludicrous gibs!
  • deronb1
    edited July 2011
    No spray equipment. I was just going to use a gloss black spray paint to match my JBL CS10 sub.
    F1nut Posts: 51,793
    edited July 2011
    While not impossible, you're looking at a ton of work to get a proper high gloss finish from a spray can. My advice, strip the vinyl, take the empty cabinets to an auto body shop and have them do it.
  • deronb1
    edited July 2011
    I will kick that around. My daughter just wrecked her car. Maybe I can have them throw in the cabinets too if I give them the business. thanks
