2.3TL Side Panels
brgman
brgman Posts: 2,859
edited July 2011 in Vintage Speakers
I have looked at numerous threads but have seen comments saying that the side panels on the 2.3TL's are glued and i saw posts saying they are clipped like the 1.2TL's.
Can someone confirm before i F these up trying to get them off?:redface::redface:
I’M OFFENDED!!!!
Post edited by brgman on
    nooshinjohn Posts: 25,928
    edited July 2011
    mine are glued
    Toolfan66 Posts: 18,066
    edited July 2011
    mine are glued
    Are you sure John??? I believe they are clipped like the big boys..
    edited July 2011
    I have never tried to take mine off, but I just went and looked. On my 1.2TL's the sides separated pretty easily with a putty knife stuck between the cabinet and the side panel. THe panels on the 2.3's didn't budge a milimeter, even with a heavy screwdriver.
  • brgman
    brgman Posts: 2,859
    edited July 2011
    Here's my deal guys.
    I bought a minty set except that they are pretty dusty and dirty from sitting.I really want to clean these sides without taking them off but masking tape rollers and vacuum aint cuttin it.
    Can i use the carpet cleaner routine while they rae still on successfully?
    They are nice and i really want to be careful so i keep them nice.
    I’M OFFENDED!!!!
    edited July 2011
    brgman wrote: »
    If you have access to some compressed air, that will work out much better than a vacuum for cleaning the grill cloth.
    F1nut Posts: 51,782
    edited July 2011
    Just to confirm, the side panels are glued on.
    You can use Resolve fabric cleaner, but don't spray it heavy as the panels are made from some sort of compressed fiber material that will not react well to excessive moisture.
