FxiA6 Side Surrounds
kevhed72
kevhed72 Posts: 5,142
edited July 2011 in Speakers
I have these as my side surrounds in a room that is roughly 13' wide....would the smaller FXiA4s be a better match for the room size. (and better match acoustically)
Honestly, the A6s are sort of an obstacle mounted to the side walls...
Post edited by kevhed72 on
    tonyb Posts: 33,072
    edited July 2011
    Have you thought about in-walls, or a more flat speaker for the sides ? I have a feeling the wife objects to the monsters on the side wall.
    Def tech Mythos has some very nice flat speaks.
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited July 2011
    The 6s are big! But, going to the 4s only takes off about 3" in height, 2" in width and an inch in depth... I say learn to live with them. Going smaller isn't going to be "a better match acoustically", unless you're just going to use that phrase to justify your downgrade. :wink:
  • kevhed72
    edited July 2011
    tonyb wrote: »
    Not so much the wife as the fear of a child running into them / hitting their head on one....in wall would be perfect, except my aversion to doing any more drywall work down there in the "family cave" :redface:
