Cs10 center channel placement
in-mn
in-mn Posts: 9
edited July 2011 in Speakers
I have a recessed opening to place a center channel. I can put it on the bottom shelf and turn it upside down so it sits at an angle pointing upwards, or i can put it flat on the shelf above it (which is about 14" from the ground).
So then if flat, it is being broadcast straight out into the knees.
If upside down and tilted, it is being broadcast up to ears, but if reclined, then broadcasted to feet.
I may be able to tilt it upside down on top shelf, but not really sure if it will work and it may be too high.
The chair is about 8' from speaker.
