help me complete my awesome bedroom setup!
so my room is rougly 18x14 with a with an alcove in one corner, but the main area is with the given dimensions. ive been building my system up for a month and half now, the sound system any way. right now i have tsi 400's for the fronts, tsi 100's for the rears, and a cs10 center all hooked up to a pioneer 1021k reciever. So as you can see there is no sub mentioned. I had a psw110 for a few weeks but it felt underpowered at a wimpy 100 watts/200 max. So i returned it and am now have narrowed it down to a few subs, the micro pro 1000, the psw 505, and the dsw 500. Ive been leaning towards the 1000 for its power and tight accurate bass. Problem is I have no where to demo one, checked a bunch of stores in the area, and i managed to get a guy on youtube to make a demo vid, but it wasnt very good. Any other videos would be greatly appreciated! My main usage is gaming and movies, my problem with the psw 110 was that I couldnt properly set it up for music so i know the micro pro will get the job done, only question is how will it do with home theater and gaming? No matter what i end up doing i will eventually this year get a second sub
thanks!
thanks!
Post edited by NathanRix on
Did you thought alredy in other sub than the Polk ones , depending on your budget you have out there better options than polk for subs ??????
Nice system...........Welcome to the Club!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
i looked at a few others at my local magnolia store, def tech, martin logan, but id think ill be plenty happy with the polk choices -
Welcome to Club Polk!
If you're mostly interested in augmenting your system for HT, I'd get a Polk DSW 600.
The MicroPro 1000 is a nice sub--I have one that I've reviewed and am waiting to send on its way. The 1000 is best suited for music (tight/deep/quick controlled bass) in a small to mid-sized room--not too big!
The 600 is perfect for a HT system in a room your size if you want to stay with Polk!
Good Luck!
what do you thing of the 500? I can have on on amazon right now for 330, the 600 is out of my price rangeWelcome to Club Polk!
Good Luck!
cnh -
The 500 is a nice sub but the 600 reaches 5 hz lower at 25hz and that makes a difference for LFEs in movie soundtracks.
Having said that, certainly the 500 will be noticeably better than a PSW110.
For that price i would take a HSU or a EPIK any given day , and most of the guys around here would agree on that
see the ones at the mag store i can get a discount on since i work at bby
so some of those nice hsu, svs etc would be out of my range too -
I don't know how significant your discount is, but when I see the psw10 listed at $199 there I'd imagine the hsu's and svs's would be a tad out of your price range (mine too!) :eek:Display: LG 47" LCD | AVR: Marantz SR5005 | BD: Panasonic BDT-210 | CD/SACD: Oppo 980 |
Amps: Rotel RB-990bx | Marantz MA-500 | Speakers: Totem Mite : Totem Mite-C : RC60i | Sub: HSU VTF-2 MKIV
HK AVR635 | Polk R30 | Sony DVD/SACD Player -
I also was taking a look at def tech super cube and a few Bice, any thoughts on those?
