Mixing CS2 with monitor 40s in front
dark1x
dark1x Posts: 1
edited July 2011 in Speakers
I found a CS2 for dirt cheap and figured I'd give it a shot. I have a CS1 at the moment, but it actually feels a bit weak at times with dialog in movies. The CS2 is a more powerful speaker, which upsets the match between the fronts a bit, but as they appear to be part of the same family, it doesn't seem like it will sound out of place.
Should these speakers work well together?
Post edited by dark1x on
  • Lietuvis91
    Lietuvis91 Posts: 908
    edited July 2011
    It'll do fine, you should see an improvement over your cs1 too!
    I'll also tell you that setting the crossover of the center at 80hz helped to clean up dialog on my system, try it if you need more clarity.
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
  • rooftop59
    rooftop59 Posts: 8,121
    edited July 2011
    They are both from the same line, have the same tweeter and crossover components, same build quality etc. the only difference is that the drivers in the cs2 are a little bigger. It should be a nice improvement overall!
    Game Room 5.1.4:
    Bedroom 2.1
  • devani
    devani Posts: 1,497
    edited July 2011
    congrats on new, bigger, and better center speaker....and soon you will want to upgrade...
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
