Sub Advice
Mike in Ohio
All - looking for some subwoofer advice as I build my system. I'm putting together a home theater/music system for a 15X20 room wiht 8' ceilings. As my mains, I have LSI9's, LSIc Center channel and LSIfx for rears. I'm going to use a yamaha RX-V671 reciever with an Emovita XMA 5 amp. As for sub I'm looking at Polk (keep it in the family) DSW micro 1000, SVS, or Velodyne.
Any recos on sub beyond that? Any input on those 3 as to what rounds out the LSI9 bottom end? Looking for a good performance/value mix to get some nice deep tight bass.
Thanks!
Thanks!
Post edited by Mike in Ohio on
What's your budget?TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
A couple of more names for you to check out: Hsu, Epik, Paradigm, Definitive Technology.I refuse to argue with idiots, because people can't tell the DIFFERENCE!
I'm trying to get out around $500 or less
