2 subwoofer hookup
New to the forum and hoping I could get some advice on subwoofer hookups.
I have been putting together my home theater for the past 6 months; here is my current configuration.
Center: Polk cs1
Fronts: Polk moniter 60's
Rears: Polk moniter 30's
Current subwoofer: Polk psw10
I have a relatively large space for the living room and everything sounds great most of the time but occasionally the subwoofer is overtaxed and doesn't perform on par with the rest of the system. I recently ordered the PSW 505 to replace my old subwoofer but I would still like to use the PSW 10.
I plan on hooking up the 505 through the subwoofer output on my reciever and i have been toying around with the idea of running the rear channels through the psw 10 and then out to the 30's. Just curious about what everyone thinks about that configuration and I am definately open to any suggestions for other possible hookup options.
Thanks for any help!
Post edited by ajsout2 on
    Tony M Posts: 11,859
    edited July 2011
    Sounds like a great idea..IF....you set your receivers' rear speaker sizes to large so if there is bass, the psw10 will put that out and cut the bass from getting to your surrounds.
    Two subs is good!!
  • Almadacr
    Almadacr Posts: 185
    edited July 2011
    I would leave like it is right now , just getting a Y splitter and run a cable
    image_mini
  • GTB
    GTB Posts: 87
    edited July 2011
    Almadacr wrote: »
    image_mini
    Personally, I'd sell the PSW10. I'm going to sell mine.....
    Greg
    Polk RTi8
    Polk Monitor 40
    Polk CSi5
    Polk MicroPro 2000
    Visio 42 LCD
    Denon AVR 790
    Samsung BD 1600
    Two Channel
    Polk SDA 2B
