Replacement Tweeters for TSi-400
philcamp1234
philcamp1234 Posts: 2
edited July 2011 in Speakers
I have blown my tweeters out and must replace them.
My question is should I upgrade them to better ones?
Also I am a newb but have done alot of reading the last 6 months. How can I protect the new ones? 50watt L-PAD? Beef up the crossover?
I listen to my rock loud sometimes, 40%/rock, 40%/movies , 20%/classical music/acoustical
:cool:
PHIL2011
Post edited by philcamp1234 on
    tonyb Posts: 33,068
    edited July 2011
    Keep the volume down is the sure way to protect the tweeters. Or get some P.A. speakers to blast away. What are you using to drive them with,and what is the source ?
    Everything has it's limits bro.
