Refaced my hall closet door
Ron-P
Ron-P Posts: 8,520
edited July 2011 in The Clubhouse
Over my weekend I refaced the coat closet door in the hallway and built and arch over the entry to the hallway. It's not quite complete yet, still a bit of detail work to do. This is the start of my new project, refacing the entire hallway. All new, big baseboards, door casings, a bit more "castle" style decor with all of this new trim work will getting painted black.
Not sure exactly what I'll do with the bedroom, kitchen and bath door ways yet, it's too much work to arch them so I will try and come up wit something that match the look I'm after.
If...
Ron loves a film = don't even rent.
Post edited by Ron-P on
  • Jstas
    Jstas Posts: 14,849
    edited July 2011
    Nice. How'd you do that door? Is it a full door or did you fake the arch above it?
    Expert Moron Extraordinaire
  • Face
    Face Posts: 14,340
    edited July 2011
    I like the gothic look.
  • Ron-P
    Ron-P Posts: 8,520
    edited July 2011
    Jstas wrote: »
    The door is a standard rectangle type, the arch above is faked. I took the door off and overlaid the T1-11 with the arch cut into the T1-11. Then, just threw on some decorative hinges, handle and cross beams.
    I'm going to do the same to the inside of my front door. The door has a half moon window towards the top. I'm going to cover it all up and cut in a small square where the window is. Then, I will built a sliding 6"x6" peep style hole. Like the ones you see on castle doors. Should be really cool.
    If...
  • Jstas
    Jstas Posts: 14,849
    edited July 2011
    Ron-P wrote: »
    Sweet.
  • sda2mike
    sda2mike Posts: 3,131
    edited July 2011
    make sure it's got that creepy creeeeek, when you open it....looks great!
  • greyford1979
    greyford1979 Posts: 749
    edited July 2011
    Looking great!!! Had a customer once that remodeled his entire basement to look like this. All the doors were carved from real wood. The pool room was the coolest, it was made to look like the inside of an old tavern and wine cellar. Only thing I didn't like was the choice of carpet in the HT room, it didn;t really fit in with the rest of the room. So,are you gonna make the bedroom into the dungeon??:tongue:
    I love animals, they're delicious!
    Tony M Posts: 11,209
    edited July 2011
    AHHHH, isn't home ownership great!!!:tongue:
    I changed alot with my house about 20 years ago and knew I was improving everything I touched...Knock on wood.:biggrin:
    Cool looks you still have going on there. The bigger baseboard will look great too.:cool: You do great work.
  • maximillian
    maximillian Posts: 2,145
    edited July 2011
    Wasn't there a sword on the immediate left wall?
  • Ron-P
    Ron-P Posts: 8,520
    edited July 2011
    You mean......this one? :) Yep, it's still there.
    If...
  • Ron-P
    Ron-P Posts: 8,520
    edited July 2011
    I really love how that closet door turned out so like I said above, I'm going to do my front door and the door (leading into the garage) in this pic as well. It just looks too damn cool.
    Thanks for the comments guys.
    If...
