if need more inputs what do do?
leftwinger57
Hello,This time I have returned w/ some good news. The Onkyo P-301 which was giving me so many problems was fixed by a friend who said it had no ouput itius.Now that were on the same audio page as it were, now I may be in need of more inputs and I do not know if this possible or not. .Right now the Onkyo doubles for my Denon1940ci cdp and the Yamaha dock system. I do not own a tt and do not see one in the future,so if needed what do I do. Is there a fitting that doubles the jacks' capacity or is what you get is what you got.I can't tell how happy it was to get back the pre and my friend said it wasn't that easy as one would think.I did try once to explain that after the openings for thr RCAs it then goes into a red housing that looks like a house on Monopoly St.I did not see of any way of taking this apart so I almost dumped it. Any way thanks again for all the help and have a safe and happy 4th and please come back safe and sound ......LW
http://www.radioshack.com/product/index.jsp?productId=3502129
Just have to get yourself an A/V switch. Not saying it's the best way to go (that would be to have the proper equipment for what you need) - but this will get the job done.65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa" -
The Onkyo has phono inputs so it shouldn't be an issue.
Unless I am missing something. The Onkyo has a Phono, CD, Tuner, Tape 1 in and out and Tape 2 in and out connections. So you have the Denon CDP in the CD input the Yamaha dock in Tape 1? So you should still have two-three more spots.
yesyour right.the omly thing that I did diferently was to use the tuner input for the dock and it worked fine ,so I guess your right and again got the answer I needed Thanks forthe pix.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
No problem, Glad we could help.
