Upgrade recommendations from current setup please?
mva5580
mva5580 Posts: 75
edited June 2011 in Speakers
Hello, I currently own the following Fronts/Center speakers and am looking into upgrading:
- Monitor 60 L/R
- CS2 Center
I think I'm pretty set on staying with Polk, so I'm just interested in some advice on what would be an upgrade that would be worth considering. Would it be either the RTi A7 or A9? I guess I just want to make sure that whathever I end up buying is worth it in terms of being able to recognize the change in speakers. I also have an opportunity to get the older RTi10's for a pretty good price.....is there a significant difference between those and the current 9/7's?
I use my speakers for pretty much everything in regards to music, movies, and gaming. Thank you for any input, I'd appreciate it.
Post edited by mva5580 on
  • bklynNupe
    bklynNupe Posts: 728
    edited June 2011
    Welcome to CP!
    What is your budget and what else are you currently running in this rig?
    emotiva xpa-2
    emotiva xpa-3
    Denon 3312ci
    Rtia9 /csia6 / FXi A6
    Samsung LN46A650
    SVS PB-12-NSD sub
    Audio Research SP-9 MKIII (GNSC mods)
    W4S ST250
    Lsi 9 (mods)
    W4S DAC-2
    Mac Mini
    Audio Aero Prima CD player
    Pro-Ject debut
  • mva5580
    mva5580 Posts: 75
    edited June 2011
    Thank you, the rear speakers are Monitor 10's, and I have a Yamaha RX-V565 receiver. I understand that I will most likely need to upgrade the receiver when it comes to moving up in speakers, and I don't have a problem with that. I just want to make sure that whatever speakers I end up getting are a solid upgrade from what I've already got.
    I would say my budget is somewhere in the ~$1,500 range for the L/R speakers. And if the price is lower for a comparable, quality upgrade, that's fine too. And the RTi10's, I have an opportunity to get a pair of those for $350, in great condition.
  • bklynNupe
    edited June 2011
    The Rtia9's are killer for HT, pretty good for music as well.
    http://cgi.ebay.com/ONE-RTi-A9-RTiA9-BLACK-Tower-Loudspeaker-Polk-Audio-/390325080239?pt=Speakers_Subwoofers&hash=item5ae13010af
    I would find a good used avr ( there is an Onkyo available in the flea market) with pre-outs and down the line you can add some used but reliable external amplification. The a9's will show their appreciation for it! :biggrin:
    If you decide on the a9's (or 7's), you can add a csi5 or csi6 center for HT.
    Good luck.
    emotiva xpa-2
    emotiva xpa-3
    Denon 3312ci
    Samsung LN46A650
    SVS PB-12-NSD sub
    W4S ST250
    Lsi 9 (mods)
    W4S DAC-2
    Mac Mini
    Pro-Ject debut
  • Lietuvis91
    Lietuvis91 Posts: 908
    edited June 2011
    It also depends on how big of a speaker you want to deal with. A9 is considerably bigger/bulkier/heavier than the m60s, so take this into consideration. Many people ignore this aspect, until they get the speaker, and then they are "surprised" at how big it is. And as mentioned above you will need an amp or a very decent avr to run a7s or a9s to let them show their stuff.
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
  • pdxfj
    pdxfj Posts: 376
    edited June 2011
    If you take your time there shouldn't be any reason you couldn't get pair of A7's and A6, plus a new AVR and an amp for $1,500. Depending on your room size the A9's might
    Head over to Accessories4less.com and find an AVR, poke around your local Craigslist and see what pops up there. Plus your current M60's and CS2 have some value which would bump your budget up a little.
    Depending on your room size the A9's might be too big. I found the M70's were too big for my room and the A7's fit much better.
  • mva5580
    mva5580 Posts: 75
    edited June 2011
    I actually am a pretty big Craigslister, and 1) have my speakers up there for sale now, and 2) have been browsing for deals.
    I've actually come across 2 that have really caught my eye, and they are:
    - A pair of RTi10's for $350
    - A pair of LSi15's, and an LSiC center for $850 total.
    The 2nd deal appears to be an amazing deal, but like you mentioned I think they're probably overwhelming for my room. I don't think I'd really get the full power out of them, as nice as they are. It's hard to pass up since the price is so great, but I'm just not sure it would make sense. Maybe some of you can speak to that though.
    Aren't the RTi10's basically the same as A7's, but just look a little different? That's probably where I'm leaning right now, but that LSi deal just keeps staring me in the face saying "You know you want to."
    EndersShadow Posts: 17,596
    edited June 2011
    If your looking at the LSi's you better have a dedicated amp or a ICE powered AVR MINIMUM.
    I run that exact LSi setup on a dedicated amp and it is by far the best set of speakers I have ever owned. 850 is a great deal and about what I paid for the exact setup (which was at a Polkie discounted rate from fellow members).
  • mva5580
    mva5580 Posts: 75
    edited June 2011
    Having taken a look at things, I'm starting to lean toward those RTi10's for $350. Taking a look at their product pages, it seems like they are the exact same thing as an Rti A7 internally....they just look different on the outside.
    If I went this way, should I expect a significant upgrade from the Monitor 60's?
    txcoastal1 Posts: 13,338
    edited June 2011
    mva5580 wrote: »
    Good answer and the put your left oer budget in a (1)pre/amp or an (2)avr
    like Pioneer SC-25/35 with ice
  • mva5580
    mva5580 Posts: 75
    edited June 2011
    txcoastal1 wrote: »
    That's what I figured, have a question for you though.
    I went to Fry's Electronics on my lunch break, as they carry the RTi A7's. I asked the guy who was working there whether or not these would be a good upgrade from my Monitor 60's, and he seemed non-committal. He said they would be a little bit better, but really didn't give me any kind of definitive "Oh yeah, definitely worth it" kind of answer. Is he a bit off on his assessment, or is it really not that big of a difference?
  • pdxfj
    pdxfj Posts: 376
    edited June 2011
    They will be a significant upgrade from your M60's and even more so when you feed them a good amount of power.
  • Lietuvis91
    edited June 2011
    mva5580 wrote: »
    You should have asked him to hook them up and let you listen, then you would already have your answer :wink:
    edited June 2011
    This is when to slow down and when you get time go and listen....yes everything this you have posted would be a significant upgrade
