Asked to make a recommendation for Denon AVR-2311...
mdaudioguy
mdaudioguy Posts: 5,165
edited June 2011 in Speakers
My brother-in-law has asked me to help him with choosing speakers.
Here's the deal -
He already bought a Denon AVR-2311 (105 wpc, no pre-outs) and he wants 7.1. Budget is not really an issue. If he had purchased a better receiver, I'd have had him in LSis, but that ain't happening now... It probably doesn't matter too much, because he just wants good HT sound - no interest really in musical sound quality.
He has a decent-sized, dedicated theater room; I'm guessing about 16x24?? So, I'm thinking I need to recommend some fairly efficient speakers. He's already planning on 2 in-ceiling rears. I thought perhaps the following might do:
RTiA5
CSiA6
FXiA4
RCi80
and then finding a fairly strong sub (HSU or Epik, maybe)
I know it's not ideal (yeah, get an amp), but would this AVR run these speakers?
Post edited by mdaudioguy on
  • mdaudioguy
    edited June 2011
  • matchan
    matchan Posts: 73
    edited June 2011
    Consider Paradigm Studio 60s
  • Almadacr
    Almadacr Posts: 185
    edited June 2011
  • Almadacr
    Almadacr Posts: 185
    edited June 2011
    For sure , they will run but i guess with time and at higher volumes your speakers will be asking more power :biggrin: , He should really consider to anything with pre outs , and regarding the subs good choices but insted having one tell him to get 2 :biggrin: like the EPIK legends :biggrin: . If he already thought about the FXi , why not keep all the surrounds with Di/bipole speakers ????
    edited June 2011
    I used to own a Denon AVR-887 years ago which was the ancestor of your model. And it was rated 100/channel. Also had PRE-OUTS back then??
    The 887 would have 'no problem' handling that speaker set in a mid-sized room. But the 2311 is newer and lighter in weight so I'm not sure how the power on the 2311 compares with its heavier forefather? I guess it should be OK.
    Is there some reason you don't want him to get an AVR with pre-outs...because if he upgrades he may need them...it may even be useful for the A5s?
    I know Denon has made it VERY hard to buy a model under 1000 with pre-outs these days. And HK has eliminated pres from the new 36XX series?
    cnh
  • mdaudioguy
    edited June 2011
    Almadacr wrote: »
    He hasn't thought of any of this, because he doesn't really know much about it. He already has two holes in his ceiling for the back surrounds... Also, my room is configured with FXi on the sides and RTi books in the back, and I like it like that! :smile:
  • mdaudioguy
    edited June 2011
    matchan wrote: »
    Why? Other than I see that they are slightly more efficient that the Polks (92 vs 90)... I mean, they better be nicer - they cost a good bit more. :wink:
  • Lietuvis91
    Lietuvis91 Posts: 909
    edited June 2011
    Almadacr wrote: »
    what does this refer to?
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
  • Almadacr
    Almadacr Posts: 185
    edited June 2011
    Lietuvis91 wrote: »
    Check this LINK :wink:
  • Lietuvis91
    edited June 2011
    Almadacr wrote: »
    Cool, thanks bud!
    tonyb Posts: 33,069
    edited June 2011
    In 7 channel mode,that receiver puts out 66 watts per channel, if he doesn't want to blast it then he'd be ok. Maybe the monitor line would be more suitable for that wattage.
  • rooftop59
    rooftop59 Posts: 8,121
    edited June 2011
    Why not bookshelfs up front with dual subs? take a lot of the heavy lifting off the reciever. RTiA3s with the csi A6 and dual subs would be pretty awesome :cool:
    Game Room 5.1.4:
    Bedroom 2.1
  • Lietuvis91
    edited June 2011
    rooftop59 wrote: »
    Oh man... now THAT"S an idea!!! I never thought of this, but it sounds like it would be a pretty neat setup :cool:
  • keeneyrm01
    keeneyrm01 Posts: 80
    edited June 2011
    You should consider Klipsch RF series. Very efficient, the RF-62 II sensitivity is 97 db, that receiver would have no problem driving a full set up of that series. A lot of people like the upfront brighter sound of the horn tweeters of the Klipsch speakers for 100% HT use like you mentioned it would be used for.
    HT basement room:
    TV- 42in Panasonic S1 Plasma
    A/V Receiver- Onkyo NR807
    Blu-Ray- 80GB Sony PS3
    Power Supply- Monster HTS-1600
    5 Disc Sony CD/DVD Changer
    Time Warner HD Cable Box
    Speakers:
    Front- Polk RTi A3
    Center- Polk CSi3
    Side Surround- Polk RTi4
    Back Surround- Polk RM6750
    Sub- Outlaw Audio LFM-1 EX
    Bedroom:
    32in Visio LCD, Sony STR-DE685 AVR, MTX Monitor 12, Sony 5 disc DVD changer
    tonyb Posts: 33,069
    edited June 2011
    also a good idea on the Klipsch. See,a couple different avenues already.
  • gp4jesus
    gp4jesus Posts: 2,016
    edited June 2011
    rooftop59 wrote: »
    why not bookshelfs up front with dual subs? Take a lot of the heavy lifting off the reciever. Rtia3s with the csi a6 and dual subs would be pretty awesome :cool:
    +1 :smile: Consider FXiA6s instead of the '4s
    *all connected w/Premiere ICs
  • mdaudioguy
    edited June 2011
    tonyb wrote: »
    Yes, I found that same bench test data and already informed him of that. That's why I suggested small towers. The funny thing is, he always wants "the best", but that receiver isn't gonna run "the best."
  • mdaudioguy
    edited June 2011
    rooftop59 wrote: »
    If it were me, I'd do that in a heartbeat. It would be harder to convince him, but I can give it a shot.
