Comcast HDTV Boston area
mccarts747
is anyone from the area? and do you have this? I want to know if anyone has this problem as well.
When i watch the HDTV channels 805,807,849,870 there is a significant volume drop off on those channels. I need to crank up the volume when on them and if i need to flip to a non hdtv channel it gets really annoying having to adjust the volume every time.
Maybe it's a problem with the cable box?? or possibly something to due with the broadcast??
I already checked all the connections.
I had a cable guy come out but, he was useless i knew more about it than he did. he didn't even have a manual, I had to print one off the motorola website...
The manual was no help either, it only gave directions for Video adjutsment.
Shawn
___________
Onkyo TX-NR609 (receiver)
Sony Blue ray Player
Sony 46" LCD TV
Comcast HDTV X1
VM10 (Center)
VM10 (Front Mains)
FXi30 (surrounds)
Cambridge Soundworks Cube8 (sub)
___________
Sony 46" LCD TV
Comcast HDTV X1
VM10 (Center)
VM10 (Front Mains)
FXi30 (surrounds)
This may have something to do with the dynamic range of a Dolby Digital source (which your HDTV signal probably carries). I notice that when I play a DVD, I have to crank the volume to get the same level as a CD or FM tuner. I know this does not offer you a solution, but it may help explain it. Have you tried www.hometheaterforum.com ??
Ray -
That's interesting. Anyone else have any experience with this?Shawn
___________
Sony 46" LCD TV
Comcast HDTV X1
VM10 (Center)
VM10 (Front Mains)
FXi30 (surrounds)
