Monitor 7
johnnywill
johnnywill Posts: 7
edited July 2011 in Vintage Speakers
Need help from the Brain Trust- bought a pair of used Monitor 7's. Looked great but had a bad MW-6502 on one of them. Bought a new one & hooked them up. Not good, sounds like volume is on .5 (when at 7) & I'm 5 blocks away. Am I screwed? My newer home theater is all Polk so I was waxing nostalgic & wanted to invest in some Vintage. I'm pretty good with electronics so before I toss them in the garbage can I'd like to bring them back to life, if possible. Need wiring diagram & opinion if they are worth saving. Thanks!
Post edited by johnnywill on
    F1nut Posts: 51,770
    edited June 2011
    Is that with both speakers or just the one that had the bad driver?
  • johnnywill
    johnnywill Posts: 7
    edited July 2011
    Sorry for the huge delay! One of the mids had a warped cone & wouldn't flex. Neither would the bass. The other speaker flexed fine. I ordered a new MW-6502. In the meantime I hooked the speakers up to my buddy's receiver (used the sames speaker wires his speakers were connected to that sounded great). Both speakers sounded very quiet & distant. Any ideas on how to troublshhot/repair?
    F1nut Posts: 51,770
    edited July 2011
    I'm thinking both tweeters are not working. Do you see a fuse on the binding post plate?
  • johnnywill
    johnnywill Posts: 7
    edited July 2011
    I feel so stupid! I looked at the fuses a week or so ago & they looked good. I bought new ones just to be safe & that was it!! However, I do have a bad tweeter. Are they still available & how do I get the model #? Nothing is on it. Both clips are identical. Lastly, is there a big difference between an MW-6500 & a 6502? I bought a '02 to replace a warped '00. It sounds fine, though.
    Thanks a ton!!
    John
    F1nut Posts: 51,770
    edited July 2011
    What do the current tweeters look like....a pic would help. Your speakers should have SL2000's in them, but they came with a label on the back, so you may have the RD0194-1 replacements already.
    Yes, you need to get the proper driver.
