Plugging in hi-current Amp
acmf74
I have two choices plugging in my amp. I either can plug it directly into the wall outlet or my APC H15 surge/power conditioner. What would be most beneficial? Thanks.
Post edited by acmf74 on
I would plug it into the H15 for the protection and the basic noise filtering. Some feel that surge protectors "limit" amp performance but I haven't seen any tests that confirm that with higher-end protectors like the H15. Quite possibly true with the el cheapo variety.
I'm sure other members have the H15 or similar and will comment.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica -
I plugged my Parasound Halo A51 straight to the wall outlet because its user manual suggested so. My sources & TV were plugged into my APC S15.Gears shared to both living room & bedroom:
Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
Living room:
LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
Bedroom:
Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
Other rooms:
Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
audio-gd NFB-10.2 / Denon AH-D7000 -
This is a tough question. APC gear is extremely well designed for the price, and I feel always feel better plugging my amps into the protected power. I do believe bass may be improved going direct to the wall (use a premium outlet), but only at the highest listening levels.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
What is the deal w/ 'premium' outlets? What's the advantage there?Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
Perhaps the single biggest advantage is that they tenaciously grip the power cord's plug. Beyond that the craftsmanship and materials used are very, very good. I have a couple of cryoed PSAudio Power Port Premiers that made a startling difference when installed; the noise floor dropped dramatically. There are some threads around here posted by DK with some nice scope traces and text to explain even more.
If you are a skeptic, probably the advantage is the vendor makes more profit on a $100 outlet versus a 99 cent outlet :biggrin:.
As an intermediate step, pepster has some good outlets that he sells to Polkies at a price you can't pass up.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels
