hooking up tsi speakers
molotov187 wrote: »hi,guys
i just got my new speakers
tsi400
tsi200
cs2
psw125
i wold like to ask you guys if you can help me with some basic info about
hooking up the speakers with the AVR its a yamaha RXv-567 that ill get tomorrow,
thanks.
Congratulations on your new speakers , you got yourself a 5.1 system ...what exactly do you want to know ???? -
thanks, i want to know about the wiring what to do and what not to, any tips about it and any thing to help me not to blow up the speakers :biggrin: -
molotov187 wrote: »thanks, i want to know about the wiring what to do and what not to, any tips about it and any thing to help me not to blow up the speakers :biggrin:
For wiring you can get a 14AWG wire from Monoprice and to keep all the connections with a clean look you can also buy some Banana Plugs .
After you have everything is plug don`t drive your speakers too loud you might damaged the speakers , they have a breaking time , drive them slowly for around 200 hours .
Most important is also to calibrate your speakers after everything is connected
To keep things simple you really just need to:
1) Observe polarity, making sure black posts on the amp are connected to black posts on the speakers and red to red.
2) Don't try to bi-wire/bi-amp the TSi400s. Just use one set of binding posts on each speaker connected to only the amp binding posts labeled Front. Ignore the rear surround / bi-amp binding posts on the amp.
3) Use a subwoofer cable to hook the sub up to the receiver. Use the LFE connection on the sub. Don't try to do anything with the speaker connections to or from the sub. You don't need to mess with those with your receiver.
Good luck, and welcome to Club Polk!! -
how many banana plugs does he need?
On3s&Z3r0s wrote: »To keep things simple you really just need to:
thanks allot this is really helpful -
thanks for the great information
Follow the instructions in your manuals and you will be A-OK.If you can't hear a difference, don't waste your money.
Nice On3s&Z3r0s
Home Theater Setup- Receiver - Onkyo TX-RZ1100
- Mains - Polk RTi A9's
- External Amps - Outlaw 2200 Monoblocks for L/R/C
- Center - Polk CSiA6
- Side Surrounds - Polk FXiA6's
- Atmos - 4 Polk 80F/X RT's
- Sub - SVS PC-4000
- T.V. - LG OLED65C7P
