Need brain power for choices
rebuy
rebuy Posts: 695
edited June 2011 in Electronics
Ok, Here is the deal. I bought a new pair of Rti 4's.
Right now I'm powering them through a Cheesy Kenwood that a friend loaned me. I'm going to buy an "Entry Level" Receiver.
I'm shopping for used and refurbished unit's.
Living room is very small, Trailer.
Looking at 30 WPC H-K with HDMI, Refurbs from Onkyo and entry level Denons.
The refurbs from Onkyo have a lot more power, 60 to 80 WPC
The Denon has a lot more power, 75 WPC.
Do you trust refurbs?
Who would have the best sound quality for the RTI's?
All boast discreet amps and high current.
Which ones would you be looking hardest at?
I want to make a good choice.
Post edited by rebuy on
  • PrazVT
    PrazVT Posts: 1,607
    edited June 2011
    For 2 ch usage, all those power ratings should be accurate. For 5.1, the HK is probably accurate in its ratings. The Onkyo / Denon power ratings would probably be closer to the HKs driving 5 speakers. I would just go with the one w/ the features you want. SQ should be comparable for all of them.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited June 2011
    Where are you located? If you have a Fry's near you they have the HK AVR1600 for $250 on sale this week.
    What's your budget?
  • Ern Dog
    Ern Dog Posts: 2,237
    edited June 2011
    I always found the Rti series to sound a tad bright to my ears- for music. So, for me it was helpful to pair the speakers with a warm sounding amp. With that being said, I used an HK 635 with my Rti10's.
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited June 2011
    How about a nice Harman Kardon AVR 254...? :wink::wink:
    Seriously, I tried my RTi4s with these in 2-channel, and was very pleased (and surprised) by the result.
