Crossover Re-Cap Question
Jer.War
Jer.War Posts: 180
edited June 2011 in DIY, Mods & Tweaks
Hey guys,
This question is for all the x-over modders out there.
I am about to put in an order at Sonicraft for capacitors to uprgrade the crossovers in my LSI15S and LSIc. My question is wheter there is any benefit to uprgrading bypass caps (not in direct current path) such as the 18uF C3 in the LSIc?? Also, should I employ a bypass cap (.1uF sonicap) if I do not change the 260uF cap??
Thanks alot...
The i was planning to order caps to replace C1 and C2 of the 15's and the center, mills resistors throughout, and some daytons for P.E for the 15's, solder, and some hook-up wire. Anything I am missing.
I will take any pearls of wisdom you have to offer in regards to this project. I plan to start with the LSIc to get me warmed up.
[The Ever-Evolving System
LSI15's (PNF Symphony cabels, modded X-Over and subs), LSIC, LSI7's, Rega Apollo CDP (PNF ICON ICs, modified PS cct.), Yamaha RXV-1700 w/ ipod dock, B&K REF200.2 (fronts) Samsung BDP-1600, XBOX360, Patriot Box Office Media Player, 42" Samsung LCD.
  • Face
    Face Posts: 14,340
    edited June 2011
    To the small values, no. To the 260uf, yes.
  • Jer.War
    Jer.War Posts: 180
    edited June 2011
    Should I ignore capacitors that arent in the direct current patch (caps that connect from the positive lead to the negative lead prior to the driver (bypass))?
