netflixs setup
recover
recover Posts: 14
I'm trying to figure out the best way to play netflixs at the house. I have an old TV so I can't stream it through it. I have an onkyo 708 receiver. I also have an iphone. I'm pretty sure that I can't go through usb from my phone to the receiver and watch it that way but if I could that would be very convenient. I'm thinking that the best way is to get a router on my home computer. I was told that doing a wire connection is best. Is that true? I would like info on which router works best were to buy etc. and any other info that might be helpful.
  • Theheadsn
    Theheadsn Posts: 413
    edited June 2011
    Linksys is always a good start as far as routers go.
    Kinda depends how much you want to spend. I run netflix through my xbox and ps3.
    And if you wanna run netflix off your computer TO your tv, the only real way is to run it though an HDMI or RCA cables from your video card on your pc, basically making your tv your monitor.
    If I were you, either go out and buy a wii, ps3, or xbox, its cheaper. Or get a newer tv that allows you to stream netflix.
    Home Theater Setup
    • Receiver - Onkyo TX-RZ1100
    • Mains - Polk RTi A9's
    • External Amps - Outlaw 2200 Monoblocks for L/R/C
    • Center - Polk CSiA6
    • Side Surrounds - Polk FXiA6's
    • Atmos - 4 Polk 80F/X RT's
    • Sub - SVS PC-4000
    • T.V. - LG OLED65C7P
  • woodhead 2
    woodhead 2 Posts: 367
    edited June 2011
    I use a Roku
    Panny 8000 project
    Oppo 103D
    Fronts- Monitor 70's
    Upper fronts- Monitor 30's
    Surrounds- Monitor 50's
    Backs- Monitor 40's
    Center-CS 350
    Sub- SVS PB 2000
    Onkyo 607[back up]
  • matchan
    matchan Posts: 73
    edited July 2011
    XBMC PC , Roku or Apple TV
  • carwashguy
    carwashguy Posts: 131
    edited July 2011
    A hundred bucks will buy you an Apple TV. It will not only play Netflix and other movie services but stream music through your stereo as well. All this provided you have a home wireless network, so that would be your first step.
    Living Room
    LSi 15
    LSi7
    LSiC
    LSiFX
    2 EPIK Empire
    2 W4S Sx-1000
    Monster HTPS 7000 MKII
    Parasound 5250
    Onkyo PR-SC5508
    Oppo BDP-95
    Pro-Ject RM 1.3
    LG 55 LED
    Bedroom
    RTi A7
    CSi A6
    FXi A6
    2 PSW 125
    Onkyo TX-NR1008
    Panasonic 60 Plasma
  • nwohlford
    nwohlford Posts: 700
    edited July 2011
    Since you have an iPhone, I would echo the suggestion for an AppleTV. If you keep music on your phone, I think that you will find the Airplay function very convenient. If you have an N wireless network, that should be adequate for NetFlix on the AppleTV (assuming your wireless router is not on the other side of a brick wall or a few floors away).
    You can get some video out of the dock connector of your iPhone using the correct cables, but last time I checked NetFlix did not support the video out on iPhone.
    heiney9 Posts: 25,659
    edited July 2011
  • mdaudioguy
    mdaudioguy Posts: 5,164
    edited July 2011
    You could also buy an inexpensive Blu-Ray player (I have a $140? LG) that also has net apps (Netflix, Vudu, Pandora, Youtube, and others).
    edited July 2011
    To the OP, just be aware all the above solutions have varied outcomes and all don't give you the same quality, ease of use or options.
