Which would be best for Sound Quality
officer dave
officer dave Posts: 20
edited June 2011 in Car Audio & Electronics
Looking at the following 2 amps the JL Audio XD 400/4 and the Massive Audio NX4. Both are small for my applicatio. Powering 4 Polk Audio MM 521 speakers with a JVC KD R720 head deck in a motorcycle fairing
Post edited by officer dave on
  • jay27
    jay27 Posts: 105
    edited June 2011
    I would go with the JL Audio as it is the more reputable brand in my opinion.
    At a minimum, you would at least know that the amp will meet or exceed its power rating.
  • arun1963
    arun1963 Posts: 1,797
    edited June 2011
    Well the Massive Audio puts out more watts. 4x100 vs 4x75 for the JL. The NX4 also gives you 24db slopes. I think for your application, you'd be better off with higher watts, as long as the NX4 actually makes the rated power and is not a crappy amp. Maybe someone here will know more about the Massive Audio. The JL of course is fine.
  • Jstas
    Jstas Posts: 14,997
    edited June 2011
    I thought you already had an amp for that setup?
    Expert Moron Extraordinaire
  • MacLeod
    MacLeod Posts: 14,358
    edited June 2011
    Whichever is the most powerful. If the Massive is 100x4 and the JL is 75x4, Id get the Massive.
  • KaosTsoc
    KaosTsoc Posts: 372
    edited June 2011
    Massive Audio is also CEA compliant so, I think it would be safe to say that the watts should be correct. Also they are really close in size as well. I think the massive will be a bit longer, but that is about it.
    Thanks.
    2006 Prerunner Access Cab
    5 Speed 4 cycl 2wd
    Audio:
    Pioneer P860 Head Unit
    Polk Audio MM6501
    Alpine PDX F-6
    Two SR124(SVC)
    Alpine PDX M12
    Kinetik HC2000 battery and Sleeve
    200 Amp Mean Green High Output Alternator
    Need a DJ, photobooth, or both for rent?
    http://photoboothdallas.org
  • Vital
    Vital Posts: 747
    edited June 2011
    + 1 for Massive Audio.
    Not sure what the price for it you were quoted but there's a few authorized dealers on DIYMA that sell them for cheaper then any other place i've seen.
    2008 Nissan Altima
    Kenwood DNX 5140
    Arc Audio IDX and XEQ
    Polk Audio SR6500 active and SR124-dvc sealed
    Polk Audio PA500.4 and PA1200.1
  • KaosTsoc
    KaosTsoc Posts: 372
    edited June 2011
    I am not sure were the amp is going to fit in your motorcycel, but if water or moisture gets on/in the amp. That may cause it to fry so, you may need to find an amp that is more marine certified. However if there is a way for you put the amp in an area where very little moisture is gonig to get into, then you should be fine.
    Thanks.
    5 Speed 4 cycl 2wd
    Audio:
    Polk Audio MM6501
    Alpine PDX F-6
    Two SR124(SVC)
    Alpine PDX M12
