GLOW AUDIO Sub One Subwoofer
dorokusai
dorokusai Posts: 25,576
edited June 2011 in For Sale (FS) Classifieds
Glow Audio Sub One Subwoofer - 10/10 - Bamboo - *SOLD* to DMara
Here's another subwoofer that I picked up for a shootout with some others but just got too busy. It could easily compliment the Audioengine A5 loudspeakers I have for sale in another thread or to add-on to another, existing system. I've heard a handful of other mini-subs like the Pinnacle Baby Boomer, Audioengine S8, the subwoofers included with the Surround Bar systems as well as the PSW111 and this is one of the more musical of the bunch.
I'd say between the bunch, the Pinnacle Baby Boomer and this one are the fastest and most musical and it's the smallest of them all at 9" square. This one is particlurly fast due to a well made 6.5" driver size complimented with an equal PR in lieu of a ported design. I believe the sealed designs blend better as well. The SBar subwoofers also sport a smaller subwoofer driver but they are tuned entirely different. This is strictly for music IMO and Polk has nothing at this level. I would say think REL if I was to reference it to another manufacturer.
This hasn't even been opened and still has the packing straps on it. I heard this subwoofer in conjunction with an entire Audioengine lineup and a Glow Audio setup using the Glow Audio Voice One at a dealers' house and grabbed it since it was the only one he had left. It would be PERFECT for a small rig or to pick up, or re-enforce the lower octave for a pair of Magnepan or Quad loudspeakers for example. It blends VERY easily.
The finish is Bamboo and overall build quality is outstanding. The panels are in Bamboo with nicely perforated grills that snap in and the edges have a tight tolerance across the board. This is a far better manufactured subwoofer than you would ever find from someone else at <$500-1000, let alone the $325 I'm selling it for here. I'm really taken by the brass footers, edge work and grills in regards to construction.
It has some serious adjustable brass spikes with built-in floor protectors. It does tend to walk a little bit under heavy load but nothing that can't be solved with a small amount of Blu-Tack under each foot. This is also a nice add-on compared to the thermoplastic spikes on the S8 and Polk subwoofers. That's probably $80 saved from picking them up from Grant @ Myesound.
Specifications:
OUTPUT POWER: 60W
FREQUENCY RESPONSE: 30Hz-160Hz
THD: 0.4%
S/N Ratio: 97dB
SPEAKER DRIVER TYPE: 6.5”
MAGNET WEIGHT: 0.53KG 1.17lb
SENSITIVITY: 95dB (1W/1M)
POWER CONSUMPTION: 140W Maximum; 7.9W in auto rest (inactive) mode
POWER REQUIREMENT: 110V/220/230V AC, 50~60Hz
AC voltage is factory set for 110/120V but is switchable for 220V operation, see manual
DIMENSIONS (L x W x H) 9 x 9 x 11
LINE IN TERMINAL: RCA stereo Connectors x 1
SPEAKER TERMINAL: Binding posts x 2
ACCESSORIES: Power cord x 1
WEIGHT: 6.8KG 14.99 lb
SHIPPING WEIGHT: 7.6KG 16.76 lb
It is packed and will be insured to withstand a nuclear blast but the original packaging looks bulletproof.
Reviews: There are two solid reviews from 6Moons(Realiszation Award Product) - 2009 and Positive Feedback(Issue 44) - 2009.
"Glow Audio's Sub One is beautifully built and superbly attractive in its anthracite/bamboo skins and classy brass footers. It performs exactly like a musical subwoofer should even in a big room - quick, properly damped, powerful, without bloat, ring or sloppiness and good into the low 30s."
"Make no mistake, the Glow subwoofer is the real deal … the doubled-up drivers of the Sub One have more kick and energize more profoundly … you can play the most beastly bass whoppers in your collection and not feel shortchanged. That it manages to do all that for $408 delivered globally is shocking. It truly is. Bravo. "
Srajan Ebaen, Editor 6 Moons.com
Includes: Original everything.
S5231SAG
Post edited by dorokusai on
  • dorokusai
    edited June 2011
    If you read the earlier thread for the Audioengine S8 subwoofer, I had the pics and verbage mixed up as I was trying to write these at the same time. Sorry for the confusion.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited June 2011
    That's friggin neat-o.
  • schwarcw
    schwarcw Posts: 7,358
    edited June 2011
    Hi Mark!
    I was a little confused by the specs on saw on the manufacturer
    s page. Does the amp on this sub have a 140 watt output capacity?
    Carl
  • dorokusai
    edited June 2011
    schwarcw wrote: »
    Hi Mark!
    It's a 60w internal amplifier and @ 95db sensitivity is more than enough for a 6.5" driver. The 140w figure is total power consumption under a full load but I wouldn't equate that to actual amplifier output since I'm unsure of the type and design.
    Better? Thanks for asking Carl, that's a great question.
  • schwarcw
    edited June 2011
    The size is compelling and the color matches my decor. I have an old 8", 100 watt HSU that is surprising big and very black. It is so musical that I can't part myself with it. However, I'm looking for a fast musical sub with just a bit more power in a smaller footprint that won't break the bank since I don't use a sub more than 20% of the time. This would be one of those components that one would have to hear because it may produce more sound and be more musical than it has a right to. The price is right and looks great. If you don't sell it, I will be in Baltimore the first week of August. I pass Damascus on my way down and back so we'll see. Thanks for the prompt reply.
    Best regards.
    Carl
  • dorokusai
    edited June 2011
    I understand. I'm a huge fan of diminutive, high quality subwoofers and this is one of them. Not every subwoofer has to hit <20hz to be awesome and far more subwoofers are nowhere close to musical. It's a misunderstood speaker since most people only think of explosions and depth charges when it comes to a subwoofer.
  • RuSsMaN
    edited June 2011
    Carl, why wait? Mark could ship a baby in a glass vase and it would arrive intact.
  • punk-roc
    punk-roc Posts: 1,150
    edited June 2011
    This thing looks incredible.. I'm currently trying to talk myself out of an impulse purchase.. How would you think these would fit with the new LSiM bookshelves, or would this add some more musical low-end to the SDA-2's?
    Jason
    2-Channel - So far...
    Pre: Dodd ELP
    DAC: W4S-Dac2
    Source(s): Computer and Denon 2910
    Amp: Parasound HCA-1200II
    Speakers: LSi9s - Vr3 Fortress Mod
  • dorokusai
    edited June 2011
    punk-roc wrote: »
    Jason
    Jason - I can only guess on these things but we were able to blend the one I heard out of the box very easily with a pair of Magnepan SMG. It was perfect. I didn't have a whole test bed of other loudspeakers to check it on but I would bet its an easy drop-in subwoofer for just about any system.
    Don't buy on impulse but it is a beautiful subwoofer in person. I'd suggest you read more about it from my link, check out some more pics and think about how it would fit into your current room....where especially. It's small enough to move around and tweak that's for sure.
    If I was to pick a speaker it would be better for, I'd say the SDA2 since it's a bit slow on the low end wherein the LSiM 703 is not in any way. I would find it more suited to a mid-size loudspeaker and spot-on perfect for Magnepan and similar low end challenged panel loudspeakers.
  • punk-roc
    edited June 2011
    ok, lemme think on it a little bit.. i've really wanted a little sealed sub to try out with a few of the different setups i have.. mostly the sda-2's and my PC setup
    Thanks for the information Mark, I'll get back to you..
    Pre: Dodd ELP
    DAC: W4S-Dac2
  • dorokusai
    edited June 2011
    punk-roc wrote: »
    No problem Jason and I want to ensure you make the right decision, not just make another sale. That's not how I operate. I assure you it will rock your PC setup. I've done subwoofers in PC rigs before and while they rule, I don't game enough cool stuff to warrant them as my Quad's handle everything perfectly since it's so nearfield.
    I recently heard a buddy's full on 7.1 gaming system with chair and it was honestly too scary for me when playing FEAR II, or whatever it's called. I think I'm starting to flake out a bit as I get older or maybe the medication is affecting my senses more than I realize. It was 100% CREEPY.
    If you do pick it up, it will be an uncommon piece for your setup. While everyone else gets something generic, you'll have something cooler and much more unique :cool:
    Mark
  • dorokusai
    edited June 2011
    Still for sale, so don't run away.
  • DMara
    DMara Posts: 1,434
    edited June 2011
    Geez, Mark, you know I own a pair of Audioengine AP4 powered by Audioengine N22 amp (LOVE THEM!!!). And of course I welcome the addition of a small fast, musical sub to the mix since my current Polk PW10 is a little bit slow and bloated for this office setup. Please choose for me, either this GLOW AUDIO Sub One or the Audioengine S8 from your other ad, I trust your judgement, as always :smile:
    Gears shared to both living room & bedroom:
    Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
    Living room:
    LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
    Bedroom:
    Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
    Other rooms:
    Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
    audio-gd NFB-10.2 / Denon AH-D7000
  • dorokusai
    edited June 2011
    The S8 is SOLD so that makes the decision pretty easy. I've heard both and believe the S8 is more matched to the A5/AP4 setup but then again it should be. The PSW10 is an awful match since it's slow, bloated and not up to par with your office setup. That N22 amplifier is super cool BTW and your rig is what I'm talking about....solid secondary rigs are easy to do, inexpensive in the bigger picture and they can be so very cool.
    That being said, this would also work just as well and it's probably a bit faster although the S8 would hit harder at the lower end of the ratings. Some alternatives would be the PSW111 from the Polk world or Pinnacle Baby Boomer, both of which would be better choices than what you currently have.
    It's up to you man, I'm just the messenger :biggrin:
  • DMara
    DMara Posts: 1,434
    edited June 2011
    That definitely made it more easy to choose :biggrin: I'll take this GLOW AUDIO Sub One.
    The Audioengine S8 would be great to match the whole set. However I got bamboo floor, so this beautiful baby will make it as a very cool decor, too :smile:
    Living room:
    Bedroom:
    Other rooms:
  • dorokusai
    edited June 2011
    DMara wrote: »
    That's perfect and the finish is truly VERY nice in person. I just got your PM, we'll work out the rest offline. Thanks Vu.
    -Mark
  • punk-roc
    edited June 2011
    wah!! =) You'll have to let me know how much you love the sub DM. I'll have to throw this on my remember to audition/purchase list
    Jason
    Pre: Dodd ELP
    DAC: W4S-Dac2
  • dorokusai
    edited June 2011
    Sometimes you have to go with your gut Jason. I know it was a serious thinking point and believe me, we've all been there. I'll find something for you personally, just give me some time.
  • dorokusai
    edited June 2011
    Shipping label created, posted, emailed tracking and dropping off tomorrow.
  • DMara
    DMara Posts: 1,434
    edited June 2011
    dorokusai wrote: »
    As fast as a vampire in the dark :biggrin: Thanks very much, Mark :smile:
    Living room:
    Bedroom:
    Other rooms:
  • schwarcw
    edited June 2011
    Nice sale! Good luck with the sub, it sure is a beauty!!!
    Carl
