Looking for good speaker wires
Hi all,
I am looking for good wires for my RTIA9`s and FXIA6`s, nothing "ultra-special" but good ones WITH TERMINATION.
Any recommendations on models and where to buy ? I am in Canada;
Thanks,
Mongo
Thanks,
Mongo
Receiver: Marantz - SR6006
Main: RTi A9's (powered by 2 Emotiva XPA-1`s, bi-amp)
Center: CSi A6
Surrounds: RTiA5's
(center and surrounds powered by Emotiva XPA-5)
Subwoofer: Infinity PS312
TV Sharp 70"
Center: CSi A6
Surrounds: RTiA5's
TV Sharp 70"
Post edited by Mongo on
http://www.bluejeanscable.com/store/speaker/index.htm
I've use the BJC Ten White (5T00UP) (White jacket, 10 AWG) and the Belden 5000UE (Gray jacket, 12 AWG) and have been happy with both.
Can't comment on their termination as I've bought it "raw" and terminated it myself, but I'm sure they are high quality.Things work out best for those who make the best of the way things work out.-John Wooden -
Opinion might be different from others... But... Monoprice.com has good wire for great $.
IMO, the best deal right now is on MIT EXp 2 cable...75% off and the banana plugs are fantastic.
Do a Google search for MIT Cable express. I have them connected to my LSi 9's and they sound great. -
Upstatemax wrote: »IMO, the best deal right now is on MIT EXp 2 cable...75% off and the banana plugs are fantastic.
Thanks, but the banana plugs do NOT fit in the Polk speakers,right (??)
Could you please clarify ?
Thanks to everybody that have been replying,
MongoReceiver: Marantz - SR6006
Center: CSi A6
Surrounds: RTiA5's
TV Sharp 70" -
Nope they fit just fine, I use the MIT Exp 2's and like them a lot, especially for the price. If not i'd go Canare 4s9's and buy banana plugs/spades and terminate yourself.
They fit perfect...
For the price of the "B-Stock", you're hard pressed to beat them. -
Didn't realize they still had them for 75% off.
Ignore my previous suggestion and go with these. I bought 3 pair and for the price they are tough to beat.Things work out best for those who make the best of the way things work out.-John Wooden -
Well, I am in Canada, I do not believe that much that the model that they sell here is different from the model they offer in USA, but the manual of my POLK speakers says that "Banana connections are only available in USA models".
I've loosen the plastic terminals completely, they don`t get out and I can`t see a banana connection, please does your model have a visible banana plug ?
Thanks,
Center: CSi A6
Surrounds: RTiA5's
TV Sharp 70" -
Thanks,
Mongo
You are correct that those sold outside the US don't have banana compatible posts. This is due to the spacing being too similar to the Euro standard for AC connection. Speakers don't take kindly to high AC voltages.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Thanks,
Mongo -
Dennis Gardner wrote: »Speakers don't take kindly to high AC voltages.
Maybe there are removable plastic plugs in the center of the binding posts?.
Well, there are plastic pieces, but they don`t look removable at all.
Thanks,
Center: CSi A6
Surrounds: RTiA5's
TV Sharp 70" -
Thanks,
Mongo -
Then maybe they use different binding posts for export models instead of just inserting plastic plugs.
I could bet that the "Canada" model is the USA one, but maybe I'm wrong; banana plugs do not fit in mine.
Thanks,Receiver: Marantz - SR6006
Center: CSi A6
Surrounds: RTiA5's
TV Sharp 70" -
Thanks, -
Thanks,
Mongo
Did you unscrew the plastic nuts all the way? The plastic plugs should simply fall out when you do.Political Correctness'.........defined
President of Club Polk -
http://www.youtube.com/watch?v=Qo1NHhRmHls
Interesting screen name. A character from one of my favorite old movies. -
If they don't take banana plugs, then MIT also sells spades that go right on the wires also.
I would just call MIT Express and ask them if they can send out spades in place of the banana plugs for the speaker connections. -
I just rewired my home and had a couple of issues.
(1) Amazon sucks. the speaker wires listed as 12 gauge wires are really 12/2 or aproximately 14 guage wires. they were also poorly constructed.
(2) I emailed a couple of other companies asking them the specific specks of their wires and Blue Jean Cables responded quickly. A couple of the other companies never responded.
(3) The cost of wires varries vastly and the quality between them is not significant if you order good quality wires from a reputable company. I paid $0.62 per foot, which was more than Amazon, but the quality is far better, and the amazon wire I ordered was a complete waste of time and money.
I ordered from Blue Jean Cables and am happy I did. the wires were of high quality and sound great.
http://www.bluejeanscable.com/store/speaker/index.htm -
Beeing in Canada i only want to say one thing ..... the binding post on the speakers bought here are the same as the speakers sold in the US , i don`t know how the OP is doing with is speakers but banana plugs they do fit , i bought mine locally because i was paying almost the same as buying them truth monoprice ( special promotion ) , but the road that i take and several friends is the monoprice way , also Bluejean cable is a very good option .
These are the ones that i got
OK, Polk Audio has replied to my message, it looks like I have to use a screwdriver to actually BREAK the center plastic piece, and I'll see the banana plugs.
With that in mind, and considering that I prefer to avoid importation taxes and not order from the US, what do you think of this ?
http://cgi.ebay.ca/NEW-15-Feet-AR-MS315C-SILVER-COPPER-10AWG-Speaker-Wire-/270709021908?pt=LH_DefaultDomain_2&hash=item3f0783dcd4
Thanks,
Center: CSi A6
Surrounds: RTiA5's
TV Sharp 70" -
Ok you want to go with a finished cable without the hassle of doing your owns , that will do the job . Just by doing a quick search in the forum here you have the back of the RTiA 9 :biggrin:
Thanks to the member SolidSqual for posting the pictures in other thread .
I use the MIT Exp 2's and like them a lot, especially for the price. If not i'd go Canare 4s9's and buy banana plugs/spades and terminate yourself...
The usual late night, every night, spammer. Good bye, you POS.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
These are the ones that i gotSamsung 60" UN60ES6100 LED, Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga: LCR mids “Foamed & Plugged**”, inside* & out
*soldered **Rob the Man (Xschop) LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & Mids - 981, connected w/Monoprice Premiere ICs
Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
also Parts Express has/had AR 12 ga @ steal! Works out to $.33/ft!Samsung 60" UN60ES6100 LED, Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga: LCR mids “Foamed & Plugged**”, inside* & out
How many set screws in the gold plated part? Lowe's sell something similar w/2 set screws
2 sets of screws
