RTA 12 Fuse
rkscwh
rkscwh Posts: 3
edited June 2011 in Vintage Speakers
My son (7yrs) cranked the volume Blew the fuse for the tweeter. It's a 1amp - 250V fuse. I purchased the speakers used and want to know if this is the proper size fuse.
  • drumminman
    drumminman Posts: 3,396
    edited June 2011
    Mine have a 0.75 amp 250V fuse - the original ones from 1984!
    Not sure if 0.25 amps really makes a difference due to the manufacturing variance, but I would go with the original value since they're cheap and you have to replace it anyway.
    BTW, I'm thinking about getting rid of mine altogether and soldering in a wire connector. I've never blown one, and I've had them cranked pretty good over the years...:biggrin:
  • Joe08867
    Joe08867 Posts: 3,919
    edited June 2011
    I believe it was a .75 amp 250v fuse for the peerless tweeters and a 1.0 amp 250v fuse for the SL2000 tweeter.
    In either case you should be fine but I believe there was a different fuse in each.
