Digital noise at top of TV?
Glowrdr
Glowrdr Posts: 1,103
edited June 2011 in Electronics
(I posted this over at Satelliteguys as well, so pardon me if this sounds geared more towards a Dish Network issue - I'm over here looking for an additional opinion as well since I'm running a TV and AVR in the loop as well)
I never noticed it when I first got my TV (bought in December) and didn't notice it at first when I got the Dish Network 922. I'm pretty sure something happened in the last 2-3 months that may have caused some of my stations to display some digital noise at the top of my screen?
I believe it only happens for local channels, but don't hold me to that. Not using an OTA, just tuning to the channel like normal for satellite.
When I say digital noise, I don't notice it moving or anything. It's more like a 1-2 pixel line spanning the top of my TV, that is a black bar with a few white sections in it. Some sections are a couple inches, others are 1/16th of an inch (55" set)
Any ideas? It's a Panny 55VT20. I tried adjusting the sat picture position in the menu, and that adjusted the picture, but I still see the top line no matter where the picture is positioned. There is a setting on my TV to display 95% of the picture "to eliminate edge noise" and that does make it go away, but it actually cuts off things like sports scores and tickers at the top/bottom as well.
Even though I have a "fix" by turning on the edge noise reduction on the TV - I'm not convinced it's always been there. Anyone else experiencing this, or is it just me?
65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa"
Post edited by Glowrdr on
    billbillw Posts: 7,792
    edited June 2011
    Nothing to freak out about. Its in the broadcast, nothing to do with your Sat box or TV. Sometimes the broadcast (especially the local channels) has a bit of noise on the fringe of the image. In the old days, this was obscured by 'over scan'. With the new flat panels, you see every pixel when viewing in 1:1 pixel mode (which is now the default mode). Many of the TVs have a viewing option to eliminate the outer edges by 1 or 2%, (maybe called Size 1 or Size2) thus obscuring the noise on the edge. The drawback is that the image has to be scaled slightly to fit the native display resolution. Scaling always means a slight degradation of the image. Purists prefer the 1:1 pixel mapping (no scaling, but leave noise on the edge at times) because it offers the best quality image. In reality, most of us won't know the difference.
  • Glowrdr
    edited June 2011
    Glad to hear it. You are correct, I do have the size 1 and 2 options. There is also an advanced option that deals with this as well. I just don't recall seeing it before, but I could be wrong.
    Here is a picture for those that are curious, or have no idea what the heck I'm talking about:
    Pioneer Elite SC-37
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Tony M Posts: 11,726
    edited June 2011
    That banding happens here also.
    I go to one of my picture modes, and then tap the top of the circle selector a few times and the picture moves up a bit with each tap.
    I think it's the wide fit mode. Why they call it the wide fit is really wierd.:confused:
    I hope your tv has that option to be able to raise that channel.
  • Evrythngmatters
    Evrythngmatters Posts: 187
    edited June 2011
    An easy fix is to go into the advanced options menu and change the size of the picture. On my Panny plasma I can set it to 1 or 2. One of the settings will increase the picture size a little so those annoying bars cannot be seen.
    EDIT:
    Well, it seems I need to read all responses since I gave the same advice as others.
    Everything matters. That is all.
    Money cannot buy happiness, but it sure can buy a bad **** boat to pull up along side it though.
  • mutelight
    mutelight Posts: 1,054
    edited June 2011
    That is the CC information in the broadcast.
    // Panasonic AE8000 // Pioneer SC-57 // Polk Audio RTi A9 // Polk Audio CSiA6 //
    // Polk Audio FXi A6 // SVS PB12-NSD Subwoofer // Logitech Harmony Ultimate // Pro-Ject Debut III //
    // Oppo BDP-103 // Microsoft Xbox One Day One Edition // Sony Playstation 4 1TB SSHD // Nintendo Wii U //
    Photo Gallery
    Movie and Game Collection
  • steveinaz
    steveinaz Posts: 19,546
    edited June 2011
    Glowrdr
    The pixel-pixel mapping of the Panasonics sometimes shows closed captioned info "pieces" at the top or bottom of the screen. The broadcast hasn't been properly sized, that's why you see it. You'll only see it with standard def material; commercials, etc that are tying to fill the screen. You can switch to a different size, and this will zoom the picture 5%---I just ignore it. It's not the TV, it's the broadcast. My Panasonic TCP-58S2 does the same thing when in "Size=2" 1 to 1 pixel mapping mode.
