Laying a Travertine tile floor
disneyjoe7
Home Improvement Question....
Has anyone used Ditra, and if so what Thinset Mortar did you use with it?
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Post edited by disneyjoe7 on
http://www.johnbridge.com/forum is probably a better place to ask that question.
But from a bit of poking around on the site and looking at the specs, etc. (and my recollections from my days as a journeyman tile setter), it looks like you use unmodified thinset for everything except wood, and latex modified thinset if bonding directly to wood. The correct trowel size appears to be 11/64” x 11/64”.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
http://www.schluter.com/7016.aspx
Open up the Schluter handbook....there is a wealth of knowledge to be read. I'm also looking at Ditra and this was the first place i went.Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
Ok I'm asking about this because what I read was Mapei Kerabond was better then Mapei Keraflor thinset. The issue I can get Keraflor but I can't get Kerabond without ordering it. So I'm confused on what people are using....
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
