Damaged surround on SDA 1B
renowilliams
renowilliams Posts: 920
edited June 2011 in Vintage Speakers
Well, to my embarrasment I have a small tear in the surround of one of my mid drivers. I found this out when a prospective buyer pointed it out to me yesterday. I think he thought I was trying to put something over on him, which I most definatley was not. Anyhow, upon close inspection the damage is right near one of the screws. i noticed that the surround itself had been replaced and the replacement surround does not have a notched cutout near the screws like the others do. So that said, how do I fix this exactly and where can I purchase the rubber surrounds.
Tim
"They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic
Post edited by renowilliams on
  • renowilliams
    edited June 2011
    OK it looks like there is two drivers with this. The rubber surround looks to be part of the driver itself, so I guess it means I need to buy two new drivers MW6509.
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Bluray: Oppo BDP-93
  • Schurkey
    Schurkey Posts: 2,122
    edited June 2011
    Photos?
    Any chance of repairing the existing surround? Perhaps a dab of adhesive, or RTV silicone?
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited June 2011
    Replacement drivers sometimes didn't have the notch and during tightening, the surround can be torn when it twists under the screw head. I trim the notch myself if they aren't on the speaker using a utility blade/box cutter.
    edited June 2011
    I had this same problem on my Monitor 5s--on one mid-driver that was a replacement, and I still haven't gotten around to fixing it. Ben said that I should just try to super glue it because it's a 'perfect' tear?
    I also have some silicon? If the tear is less than an inch (which mine is) I really don't see how trying to repair it would cause any problems since the driver itself is pretty 'new'?
    But since you're trying to sell these that might not work. Mine were sold to me in this state? I never gave the seller any grief about that nor called him out though it was 'uncool' to not let me inspect the speaker when I picked it up. At least you did the right thing. I simply bit my tongue.
    Good Luck!
    cnh
  • renowilliams
    edited June 2011
    Anyone know Ballpark what a pair of MW6509 Drivers would cost? Also, one is a bass driver the other is the directional/bass driver, does this mean they are specifically ordered as a result??
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Bluray: Oppo BDP-93
  • renowilliams
    edited June 2011
    Well...It looks like its going to cost me $150.00 to get two new drivers as they have to come from California. I might as well keep my damn 1B's.
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Bluray: Oppo BDP-93
  • drumminman
    drumminman Posts: 3,396
    edited June 2011
    I'm not an expert, but they were glued to the frame when they were made during original production, so you should be able to reglue them if the problem is where they attach to the frame.
    If it's a tear elsewhere in the surround that might not work.
    When surrounds are replaced during repair that's pretty much how it's done. I would google it to see what you come up with before spending $150.
    Tony M Posts: 11,621
    edited June 2011
    Vinyl window 6" tape (for sealing around the flanges) from a vinyl siding contractor. Just a piece is all you need. Not a whole roll.
    Take driver out, and put a sliver of this tape on the backside IF that is where the tear is. (on the surround)
    Works like a charm and will last 50+ years. I've done a few.
  • Joe08867
    Joe08867 Posts: 3,919
    edited June 2011
    Try Midwest speaker repair. They sell butyl rubber surround kits. for 35.00 a pair.
    http://www.midwestspeaker.com/refoamkits.html
