LSi9 w/ integrated rcvr amp or seperate amp advice???
haveldl
haveldl Posts: 19
edited June 2011 in Speakers
Hello All,
I need some advice before I go and drop some cash. I currently have a 2ch setup: Yamaha Receiver RXV659 rated at 100 wpc @8ohms and hooked up to my LSi9's. I have the receiver set to 6ohms and I am not sure of the wattage. The receiver claims to be high current.
It sounds OK but not what I was expecting. I am wondering if I were to purchase a seperate power amp say around 150-200 wpc at 4 ohms would there be a noticable difference or would I just be wasting money?
Brains: Marant 7701
Power: Adcom 7605 (center & surrounds)
Power: Carver TFM 35x (mains)
Mains: LSi 9
Center: LSi C
Side: FXi A6
Rear: LSi 7
Sub: DSW Pro 660i
Video: Oppo Bdp 103
TV: Sony 46 HX820
Control: MX 850 Orion
"One shot, One Kill" Semper Fi
Post edited by haveldl on
  • cfrizz
    cfrizz Posts: 13,415
    edited June 2011
    Welcome to Club Polk!
    Go to Audiogon and get this amp, It will drive your speakers to their full potential.
    http://www.audiogon.com/cgi-bin/cls.pl?ampstran&1312740761&/Parasound-HCA-1500A-power-amp
    When it comes to powering the LSI's more power is better, and you should look for an amp that puts out 200wpc @ 8ohms.
    The above listed Parasound will do a great job. I gave my brother mine to drive his LSI 7s.
  • haveldl
    haveldl Posts: 19
    edited June 2011
    Thanks. I will gvie that a try and see how it does.
    Brains: Marant 7701
    Mains: LSi 9
    Center: LSi C
    Side: FXi A6
    Rear: LSi 7
    Sub: DSW Pro 660i
    Video: Oppo Bdp 103
    TV: Sony 46 HX820
  • PrazVT
    PrazVT Posts: 1,606
    edited June 2011
    +1 for the Parasound. There are a couple of NAD c272s on audiogon for the same $$ too. 150wpc @ 4/8 ohms and 340wpc dynamic.
    ALL BOXED UP for a while until I save up for a new place :(
    Home Theater:
    KEF Q900s / MIT Shotgun S3 / MIT CVT2 ICs | KEF Q600C | Polk FXi5 | BJC Wire | Signal / AQ ICs | Shunyata / Pangea PCs | Pioneer Elite SC 57 | Parasound NC2100 Pre | NAD M25 | Marantz SA8001 | Schiit Gungnir DAC | SB Touch
    2 Channel:
    Polk LSi9 (xo mods), Polk DSW MicroPro 2000 sub | NAD c375BEE | W4S DAC1 | SB Touch | Marantz SA-8001 | MIT AVt 2 | Kimber Hero / AQ / Signal ICs | Shunyata / Signal PCs
    tonyb Posts: 33,015
    edited June 2011
    Your receiver doesn't have the proper power for a 4 ohm speaker such as the LSI's. I know others told you to get an amp which is correct,but I don't think your receiver has preouts to hook it up. Could be wrong,but check first before blowing the coin on an amp.
  • PrazVT
    PrazVT Posts: 1,606
    edited June 2011
    I checked - the RX-V659 has pre-outs.
    Home Theater:
    2 Channel:
  • Lietuvis91
    Lietuvis91 Posts: 908
    edited June 2011
    I have the 1500a, and have to say that there is considerable difference in sound between this amp and 1000a when driving my m70s. A very nice amp I think!
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
  • PrazVT
    PrazVT Posts: 1,606
    edited June 2011
    I think the 1500A is higher current - 60A vs 45A for the 1000A. The 1000A is nice though - I power my center speaker w/ it.
    Home Theater:
    2 Channel:
  • Lietuvis91
    edited June 2011
    Agreed, both are definitely nice amps and I also use my 1000a to drive the center.
