upgrade to ib can it be done?
goingganzo
goingganzo Posts: 2,793
i was thinking about a small upgrade. changeing strykeforce to strykeforce ib but i dont know if it would work. where i have the back of the sub box is in the lundry room but it has a opening to the rest if the basement and so dues the ht. but the distance is about 30 feet form the back of the sub to the entrance of the ht.
also i can set it up so i can upgrade from 2 to 4 to 6 subs with the same size opening.
Post edited by goingganzo on
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited September 2003
    There can be no openings between the rear and front spaces. A split level with side wall into a basement or an adjacent fruit cellar, etc. work best. You will need a bunch more drivers too.
    SVS
