Serial Number look up or need expertise
knie0012
knie0012 Posts: 47
edited June 2011 in Vintage Speakers
The guy I might buy from is adament they are 2B's but the manual says SDA 2A's
He wouldn't let me pull the drivers to check numbers.
Pin/Blade IC, real wood caps, no risers.
here's the link:
http://madison.craigslist.org/ele/2411509313.html
350 is too high I suspect.
Does anybody have a serial number database or knowledge of serials to look?SDA 2 - SN 20748 (right)
Thanks,
Jason
Post edited by knie0012 on
    F1nut Posts: 50,768
    edited June 2011
    Obviously, the manual is the wrong one.
  • knie0012
    knie0012 Posts: 47
    edited June 2011
    Sorry for my ignorance...was that sarcasm? So they are 2B's.
    I could use this?
    Here are a few pics:
    And here is the table I was going by originally, but don't know what AI-1 means:
  • headrott
    headrott Posts: 5,496
    edited June 2011
    I bought my 2B's about 10 years ago and they also came with a 2A manual. The manual is incorrect. They are 2B's. I did the 2BTL modification to them without a problem. I don't think they made 2A's with a pin/blade connector. I could be wrong though. I hope this helps.
    Greg
    F1nut Posts: 50,768
    edited June 2011
    Look at the picture on the front of the 2A manual, compare it to the speakers in the ad.....not the same speakers, therefore they are 2B's. Another clue, the 2A's never came with the pin/blade cable.
  • WastelandWand'r
    WastelandWand'r Posts: 466
    edited June 2011
    2B's and with the cables thrown in for free they are a smoking deal!:biggrin:
    Offer him less and see where it goes. Bringing them back to AK?
    Nathan
    Home Rig
    SDA 2.3TL's front and center
    Polk 1000p Center
    Pioneer Elite SC35 Receiver (Pre/Surround
    Sunfire Cinema Grand 5X200-Back in the mix.
    OPPO BDP-93
    Squeezebox
    Stepped up to name brand Speaker Cables and interconnects!
    Monitor 4, 5, 7, 10's, SDA 1B's, 2B's, 2.3TL's, RTA 15TL's all in storage waiting for me.
    Sales Rating #1!!
  • knie0012
    knie0012 Posts: 47
    edited June 2011
    All good points!
    F1, I did catch that about the pic. I had my brother take a picture of it for that reason (sort of). Didnt know about the p/b. Thanks again.
    As for AK, you are correct. But, my brother lives in Madison, and he'd buy them for me and sit on em for a few years, or until someone drives up with room. The pickins are thin in these parts, and I need to get a pair of 2B's eventually. I've read sooo much about the 2B's and the TL mod.
    Thanks for the help!
  • inspiredsports
    inspiredsports Posts: 5,501
    edited June 2011
    My SDA 2B's came from the dealer with the exact same manual your seller is picturing, PLUS another that says "ADDENDUM TO THE INSTRUCTION MANUAL". The Addendum pictures the more modern design with wooden caps and no risers, and the specs for the 2B (and 2A's and 1C's).
    By image and specs, your seller is definitely selling 2B's.
    My Serial Numbers are shown in the format "L SDA II 14929" and "R SDA II 14983"
    2B's are worth owning and in the scope of things after $500+ of mods (RDO-198's, caps, resistors, spikes, rings, Dynamat Extreme, binding posts, custom SDA cable) to make them perfect for 2011, whether you buy them at $225 or $350 isn't a huge difference.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
    Toolfan66 Posts: 17,338
    edited June 2011
    2B's as stated above..
    Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
    SVS SB16 X2
    Cary SLP-05/Ultimate Upgrade.
    Cary SA-500.1 ES Amps
    Cary DMS 800PV Network
    Jolida JD9 Fully Modified
    VPI MW-1 Cyclone RCM
    MIT Shotgun 3 cables throughout / Except TT, and PC’s
  • knie0012
    knie0012 Posts: 47
    edited June 2011
    Got them for 3, they are mint. Now for the gimpod board and TL upgrade?
    Thanks for the help guys, as always. Top notch.
    Jason
  • On3s&Z3r0s
    On3s&Z3r0s Posts: 1,013
    edited June 2011
    The TL upgrade is definitely the obvious next step. I used gimpod's boards and they make it very easy... no messing around with awkward cap mounting arrangements. I think replacing the binding posts makes a big difference too, including an extra set so you can put one in each speaker to take the place of the stock SDA IC socket. The difference is easily discernable, and it's an easy and fairly inexpensive mod. The other mods mentioned are worth doing too if you've got the time and have them open anyway.
