Pioneer Elite VSX-21TXH question.....
shawn474
shawn474 Posts: 3,052
edited June 2011 in Electronics
I just received this from Trey (Thanks so much for the quick shipping and great packing!!!!!). I have it all set-up except for one problem. When I switch sources (TV to DVD or vice versa) the audio stays on Dolby PLII + THX. I can manually change the setting, but it never gets to DTS or Dolby Digital, DTS master, etc. I have the signal select set to auto, but as far as I can tell it just stays on the same setting. Will it say on the display or does it do it discreetly if the audio format changes?
Thanks in advance for any help.
Shawn
Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4
Post edited by shawn474 on
    VR3 Posts: 28,938
    edited June 2011
    Dont put it on "Auto surround" --
    Put it on DIRECT BYPASS
  • shawn474
    edited June 2011
    Thanks Trey; any idea how to do that? I looked through the manual and played around for a bit trying to find that setting before and couldn't get to it.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
    VR3 Posts: 28,938
    edited June 2011
    For direct bypass - you need to hit automatic/direct until it says direct bypass on the receiver.
  • shawn474
    edited June 2011
    Trey,
    That is what is confusing me. I can get to the DIRECT setting on the AVR, but it goes to 2 channel. I know it's because I have a setting wrong somewhere but cannot figure out what or where. Sorry to kee pestering you and others about this, but any way you can walk me through the steps?
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
    VR3 Posts: 28,938
    edited June 2011
    Hmm that is odd. What is your source?
  • shawn474
    edited June 2011
    The source I am using right now while testing all this is the HBO HD channel through my FIOS box.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
    VR3 Posts: 28,938
    edited June 2011
    My buddy had a similar issue with a PS3 - when he plugged it in the PS3 changed its audio setting and we had to go in and manually change it on the source but after that it was fine..
    Let me know
  • dorokusai
    dorokusai Posts: 25,577
    edited June 2011
    Why not reset the unit to factory default?
    VR3 Posts: 28,938
    edited June 2011
    Are you sure the channels is broadcasting in dd/dts??
  • shawn474
    edited June 2011
    OK I am stupid. I had the optical cable going from the AVR to the TV instead of from the AVR to the cable box. I switched it to the cable box and it works fine now. Thanks for dealing with my stupidity.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
    VR3 Posts: 28,938
    edited June 2011
    Awesomeness...
    Thats a bad **** little AVR - I like mine alot.
  • dorokusai
    edited June 2011
    shawn474 wrote: »
    Isn't that what I told you to do on the phone Shawn?
  • shawn474
    edited June 2011
    dorokusai wrote: »
    Of course it is; why in the holy blue hell would i ever listen to you? It would be too easy for me to actually listen to someone who knows what they are doing!!!!:wink:
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • dorokusai
    edited June 2011
    shawn474 wrote: »
    Lol....at least it's fixed and in all fairness we were talking about a bunch of scenarios and hookup methods.
  • shawn474
    edited June 2011
    Now just to figure out the same thing for the Blu Ray player.......
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • shawn474
    edited June 2011
    OK so I don't know if I am taking advantage of all the AVR has to offer. I just want to run the connections by everyone to see if I can do this more efficiently or if there is another way to connect everything to maximize the potential.
    I have the following components:
    AVR: Pioneer Elite VSX-21TXH
    Television: Samsung LN46B640
    DVD Player: Sony BDP-S1000ES
    FIOS HDDVR Box: Motorola QIP 7216 1
    My connections are as follows:
    TV to HDMI Out on AVR via HDMI cable
    Sony Blu Ray player connected to AVR via HDMI cable to BD on back of AVR
    Motorola box to TV via HDMI cable and to AVR via Optical cable
    My questions are:
    1. Is there a better way to hook it up? Maybe more efficient?
    2. I have it set to Direct right now on the advice of Trey. That decodes the audio signal and "upmixes" it to the highest quality (Digital, DTS, etc). When I have it on Blu Ray it says PCM. I was watching Avatar last night which is supposed to be broadcast in DTS Master HD. However, that did not show on the display. Was it in fact being played on DTS HD Master or do I have to tweak the settings to get it to properly do this?
    This is my first attempt into HDMI. I must say I am much more comfortable using the older technology; I guess because of my comfort level having set up a lot of rigs. I just feel like I am missing something on the settings or something with the HDMI aspect that I am not getting everything I can out of the AVR.
    Thanks everyone,
    Shawn
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
    edited June 2011
    I have the same receiver and when I have it set to "auto" it detects the highest form of audio first. No problems getting DTS HD master audio. Make sure your bdp is setup properly to output the signal and another thing to try is plug the bdp into the DVD input on the back. That lets the receiver do all the decoding. If you use the bdp input, then there seems to be an issue at times between the receiver and bdp as to who is doing what.
    VR3 Posts: 28,938
    edited June 2011
    I would just run your cable box straight to the AVR and get rid of the Optical cable... IMO
  • shawn474
    edited June 2011
    tonyb, thanks for the input. I reset my Blu Ray player and it walked me through the set-up again. The problem was that with my old pre, I was running 5.1 multichannel. The settings confused the AVR. After the reset, it works perfectly. Avatar was amazing!!!! Thanks for the help.
    Trey, I think I am just going to get another HDMI cable long enough to run from the cable box to the AVR. If I am understanding correctly, I wouldn't need the optical cable at all after that. I would run HDMI to the TV from the AVR, HDMI from the cable box to the AVR and HDMI from the blu ray player to the AVR. Am I correct that I would only need 3 HDMI cables and it would complete that part of the setup? I also have a zone 2 amp and a cd player connected with RCA's that work just fine.
    Thanks again for everyone's help.
    Shawn
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • Obsession18
    Obsession18 Posts: 191
    edited June 2011
    I have the same unit, I run HDMI cables from both my blueray and FIOS box to the receiver than another HDMI cable from the receiver to my TV. Works like a charm, I leave it in "auto" mode and it always picks the best audio format.
    The only time I get "out" of auto mode is when I listen 2-channel, then I go "analog direct", I don't want any unwanted signal processing mucking up the sound of my Jolida CD player.
    2-Channel System
    Analog: VPI Traveler TT, Audio Technica 150MLX, Pro-Ject Tube Box DS
    CD Player: Jolida JD-100 Preamp: Cambridge 840E Amp: Odyssey Kismet Stereo
    Spkrs: Tyler Acoustics Linbrook Signature Systems
  • dragon1952
    dragon1952 Posts: 4,907
    edited June 2011
    shawn474 wrote: »
    Geez...you'd think that would be close enough :rolleyes:
  • shawn474
    edited June 2011
    dragon1952 wrote: »
    Hahaha! I thought so too.
    I actually stopped at TJ MAxx today and found a 12 foot Hemingway cable that was just long enough for my run. It was 10 dollars!!!!
    So I have the tv, cable box and blu ray hooked up via hdmi and the cd player with rca's. Then I have a set of component cables for the on screen display menu. It's really nice to have so few cables to deal with and does wonders for the WAF!
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • 27dnast
    27dnast Posts: 255
    edited June 2011
    I have the same Elite AVR... kind of off comment, when I ran the MCACC (several times) the results made my speakers sound almost like they were playing through a tin can. It was very frustrating... my old Pioneer AVR also had MCACC and it never game me the same results (in the same room with the same speakers).
    After having the same result, I kept the speaker distance results and then manually set the speakers myself.
    Kind of a bummer.
    Any ideas?
    -27
  • shawn474
    edited June 2011
    I just read my reply and have no idea what a Hemingway cable is; it was an hdmi cable (damn autocorrect)!
    I thought the auto calibration worked well. But I might do a manual calibration with my spl meter to see if there's much of a difference.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
    edited June 2011
    27dnast wrote: »
    Kind of a bummer.
    Any ideas?
    -27
    Most the time, people make the mistake of not having the mic at ear level in your listening position. Also making sure of no other noises going on at the time of auto calibration. Even then, it doesn't always get it right or to an individuals taste. It will however give a great starting point,and then you can tweek the settings to your liking. You can then store those settings in the receiver. I found mine set my speaker levels too low so I had to bump them up manualy. Not a bummer at all, you just have to do the final tweeks yourself.
  • 27dnast
    27dnast Posts: 255
    edited June 2011
    I definitely had it at ear level... atop a tripod in the center seat.
    I'm about to set-up some new speakers... hopefully I'll have better luck. I essential did what you suggested last time (I kept the distance and level computations and then tweaked the speaker settings on my own). I had such good luck with the MCACC with my old Pioneer receiver that I was shocked when the more expensive elite didn't give me the same results (with the same exact speakers and configuration!!!
  • shawn474
    edited June 2011
    27dnast wrote: »
    There could be a setting that you missed or something on the initial configuration. I just performed the auto setup with the exact same receiver and the results were very impressive. Maybe doing a hard reset of the unit and starting over from scratch with hook-ups etc. would help and see if you get the same result.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • 27dnast
    27dnast Posts: 255
    edited June 2011
    How do you a hard reset??????
    Do you think the results (before and after) using mcacc are "night and day" in terms of sound quality??
  • shawn474
    edited June 2011
    I don't know how to do a hard reset? I can try to help find out but might want to call pioneer.
    Yes, it was absolutely night and day. Not to say that it's perfect because it could use a couple tweaks, but it was a very noticeable difference.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • 27dnast
    27dnast Posts: 255
    edited June 2011
    Cool... good to know. I'm in the process of installing new speakers now... going to be a few days before all my necessary supplies arrive. BUT, I'm definitely *hoping* that the MCACC will work with my new gear this go around.
    I'll look into the hard reset...
    Thanks, bro!
