swithched and unswitched outlets
leftwinger57
leftwinger57 Posts: 2,917
edited June 2011 in Electronics
Hi guys, As one problem got solved a curiosity popped it's ugly head when going through my fix.When my Onkyo p-301 was a working pre-amp it had switched and unswitched outlets that allowed you to plug in other devices and to turn on when you turned on the Onkyo if using the switched outlet. Now after doing the reconfiguring w/ the pre-outs I noticed very late in the game that my Yamaha RX-V665 has no such outlets at all. I then just for giggles I happen to have the spec sheets for all the Denon avrs from 2310ci up to 4810ci and all of them have outlets. Can this just be a cost cutting move by Yamaha because it seems that electrically it doesn't matter whether you have outlets or not. So guys do your avrs have outlets and do you consider this a drawback or failure of design in any way not to have them.Or am I just digging more dirt to fling around......LW
  • Joe08867
    Joe08867 Posts: 3,919
    edited June 2011
    Have had AVR's with and without. Don't know if it was good or bad but I also never used them.
    heiney9 Posts: 25,421
    edited June 2011
    Don't use the outlets in components.
    tonyb Posts: 33,069
    edited June 2011
    heiney9 wrote: »
    Ditto....don't be plugging in any other pieces of gear into those outlets. Mainly people can use them for adding cooling fans if the gear is in a cabinet other than that they aren't much use for anything else.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited June 2011
    I would find that a draw back not having a switched outlet. I use them to power up a small wall transformer to power up amps.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    edited June 2011
    Fans and the occasional FM powered antenna for radio reception. I'd miss having an outlet or two on an AVR as well.
    Did the Yamaha's predecessor, the 663 have them? Usually when you get up to around $700 or so, almost everything has at least one of these?
    cnh
  • Jer.War
    Jer.War Posts: 180
    edited June 2011
    My Yahama RXV1700 Has two switched outlest, but no switched. I refrain from using them for a few reasons, mainly minimizing the "noise" introduced into my system, and not robbing current from the main device (unit with the outlets).
    [The Ever-Evolving System
    LSI15's (PNF Symphony cabels, modded X-Over and subs), LSIC, LSI7's, Rega Apollo CDP (PNF ICON ICs, modified PS cct.), Yamaha RXV-1700 w/ ipod dock, B&K REF200.2 (fronts) Samsung BDP-1600, XBOX360, Patriot Box Office Media Player, 42" Samsung LCD.
  • leftwinger57
    edited June 2011
    Well now, it does seem just like pretty much everything else it is a matter of opinion.With most going w/ the no way to the outlets. I'm glad I brought it up because I thought it was just easier to turn on one device than all, but that's just me maybe being lazy. Still the question is why on some brands and on a fairly top model avr they do not have any and on other makes of similar quality and cost they do. I know it's not the end of the world and it was just something I noticed...
    tonyb Posts: 33,069
    edited June 2011
    Thats like asking why on some cars do they still offer up a cassette player. Really it's an added feature that nobody really uses. So why then ? Call one up and ask them. Not like it would sway anyones decision to buy their product or not.
  • CNWDI
    CNWDI Posts: 91
    edited June 2011
    I don't use the outlets in components if I can avoid it. I do have one powered FM antenna that's plugged into one, though. I'm also using an HDMI-to-component converter for use with an old (HD CRT) TV, but said converter goes wonky if left powered up for 24 hours. For the latter, a switched outlet on the TV or some nearby piece of gear would be better than pulling the (not very well made/attached) 5VDC supply cable out every time I no longer need it.
    Current polk speakers:
    Family room 5.1: TC265i R/L, VM10 Center, RC65i surrounds (couldn't match the TCs)
    Basement non-dedicated 7.1 HT: SDA-CRS+ R/L, 255c-LS Center, LSiFX surrounds, RC80i in-ceiling rear surround, plus Wharfedale 12" sub (some day I'll get around to building 15" F-20 sub).
  • dorokusai
    dorokusai Posts: 25,576
    edited June 2011
    As Heiney stated previously, don't use the outlets provided by other gear for anything but generic uses, NOT additional equipment.
    You should utilize the 12v triggers or additional outlets provided by your outlet strips, centers or whatever power control module you have selected for surge supression instead. It's safer and a better choice in regards to proper power usage and routing to avoid thumps, instantaneous overload, ground problems and a whole host of odd issues when it comes to AC.
  • Glowrdr
    Glowrdr Posts: 1,103
    edited June 2011
    No rear plugs on my SC-37, but I did have a switched/unswitched on my H/K and it was actually quite convenient. I had the unswitched for my squeezebox charger, and the switched went to a little light up x-mas tree during the holidays. lol
    Weren't those plugs only rated for a couple hundred watts with no amperage anyways? I doubt they would run much more than a CD player at that level.
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
  • dorourke07
    dorourke07 Posts: 298
    edited June 2011
    dorokusai wrote: »
    +1
    I would not feel the equipment was grounded properly or receiving the power it needs just plugged into the avr.
    Mains - LSi9's
    Center - LSiC
    Surround - pair of TL3's
    Amplification - Parasound 2125
    AVR - Onkyo 706
    CD/SACD - Onkyo DV-SP506
    SUB - MartinLogan Abyss
    55" Panasonic Viera TC-P55GT30 3D
    Bluray - DMP-BDT310 Panasonic
