A good center channel mount???
Post edited by 27dnast on
Well.. for what it's worth... the tips of the Y spread are roughly 15" apart... and it has about 17 inches of depth... can hold 50lbs. It looks like a very discrete way of mounting a CSi A6.
I ordered it. I *think* that I can make this work. Might be a little rigging involved... but it will be extremely discrete and very stable. Heck, for 28 bucks (got it for a steal), if it stinks, no biggie.
(very nice that I could share this thread with myself)
For those of you wondering... this is a fantastic center mount for the csia6.
Solid and sturdy. It allows me to have the csia6 about 5-6" away from the wall. The mount was easy to install... I slipped a thick zip-tie through the kickstand hole on the back of the speaker and attached it to the mount itself.
The speaker is going nowhere.
So... if anyone out there is looking for a way to mount their CSiA6 below their tv, off a wall... this is definitely one really good/viable option. -
Have you tried searching Amazon? They have quite a few of them.
I read the reviews for ones on amazon. Mixed, definitely, for larger/heavier speakers. The above mount - while meant for av equipment, more than does the job.
